test
test
[{"id":"f10a1076.cc20b","type":"tab","label":"Google Now"},{"id":"5e61d8f5.683d08","type":"http in","z":"f10a1076.cc20b","name":"Request","url":"/google","method":"get","swaggerDoc":"","x":85,"y":109,"wires":[["fa63c682.86a698","d86d0365.9314"]]},{"id":"bd8d0057.3561f","type":"http response","z":"f10a1076.cc20b","name":"Response","x":948,"y":103,"wires":[]},{"id":"fa63c682.86a698","type":"debug","z":"f10a1076.cc20b","name":"","active":true,"console":"false","complete":"req.query.text","x":340,"y":36,"wires":[]},{"id":"a95df868.6e9e18","type":"inject","z":"f10a1076.cc20b","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":116,"y":238,"wires":[["5e27cf7c.87c67"]]},{"id":"d86d0365.9314","type":"function","z":"f10a1076.cc20b","name":"Analyze voice command","func":"var temp = msg.req.query.text;\nmsg.payload.command = 0;\nmsg.payload.success = false;\n\n// removing rubbish\ntemp = temp.toLowerCase();\ntemp = temp.replace(\"a \",\"\");\ntemp = temp.replace(\"the \",\"\");\ntemp = temp.replace(\"to \",\"\");\ntemp = temp.replace(\"home \",\"\");\ntemp = temp.replace(\"lights\",\"light\");\n\n// check if the command is to turn something on/off\nif (temp.indexOf(\"turn\")>-1) {\n    temp = temp.replace(\"turn \",\"\");\n    msg.payload.command = 1;\n}\nif (temp.indexOf(\"switch\")>-1) {\n    temp = temp.replace(\"switch \",\"\");\n    msg.payload.command = 1;\n}\n\n// check if the command is about the solar panels\nif (temp.indexOf(\"solar\")>-1) {\n    temp = temp.replace(\"solar \",\"\");\n    msg.payload.command = 2;\n}\n\n// let's try finding the thing and state\n// the turn/switch commands are expected as 'turn <state> the <thing>'\nvar lastIndex= temp.indexOf(\" \");\nvar voice_state = temp.substring(0, lastIndex).trim();\nvar voice_thing = temp.substring(lastIndex+1,temp.length).trim();\n\n// evaulate the state\nif (voice_state===\"on\") {\n    msg.payload.command_value = \"1\";\n}\nif (voice_state===\"off\") {\n    msg.payload.command_value = \"0\";\n}\n\n// handle the solar request\nif (msg.payload.command===2) {\n    msg.payload.response=\"The solar system is currently generating \" + global.get(\"growatt_power\") + \" watts. Total generation today is \" + global.get(\"growatt_today\") + \" kilowatt hours.\";\n}\n\n// handle the switch commands\nif (msg.payload.command===1) {\n    switch (voice_thing) {\n        case \"christmas light\":\n            msg.payload.response=\"OK, turning \" + voice_state + \" the \" + voice_thing;\n            msg.payload.success = true;\n            msg.payload.command_thing=\"Sonoff1\";\n            break;\n        case \"test light\":\n            msg.payload.response=\"OK, turning \" + voice_state + \" the \" + voice_thing;\n            msg.payload.success = true;\n            msg.payload.command_thing=\"Test\";\n            break;\n        default:\n            msg.payload.response=\"Sorry, I did not understand turning \" + voice_state + \" the \" + voice_thing;\n            msg.payload.success = false;\n            break;\n    }\n}\n\n\n\nreturn msg;","outputs":1,"noerr":0,"x":366,"y":104,"wires":[["a695aaf0.376488","2138e92c.d64296","973d8cab.37a9"]]},{"id":"a695aaf0.376488","type":"debug","z":"f10a1076.cc20b","name":"","active":true,"console":"false","complete":"false","x":864,"y":211,"wires":[]},{"id":"2138e92c.d64296","type":"switch","z":"f10a1076.cc20b","name":"Check if command was valid","property":"payload.success","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","outputs":1,"x":423,"y":311,"wires":[["a2cac641.fbd748"]]},{"id":"a2cac641.fbd748","type":"switch","z":"f10a1076.cc20b","name":"Check command","property":"payload.command","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"}],"checkall":"true","outputs":3,"x":128,"y":411,"wires":[["a1658db8.a14f8","6c537189.6ac2d"],[],[]]},{"id":"a1658db8.a14f8","type":"switch","z":"f10a1076.cc20b","name":"Christmas light?","property":"payload.command_thing","propertyType":"msg","rules":[{"t":"eq","v":"Sonoff1","vt":"str"}],"checkall":"true","outputs":1,"x":399,"y":398,"wires":[["679a67b2.f0ba68"]]},{"id":"679a67b2.f0ba68","type":"function","z":"f10a1076.cc20b","name":"Put value to payload","func":"msg.payload = msg.payload.command_value;\nreturn msg;","outputs":1,"noerr":0,"x":618,"y":399,"wires":[["1af837e2.52f558"]]},{"id":"973d8cab.37a9","type":"function","z":"f10a1076.cc20b","name":"Put response into payload","func":"msg.payload = msg.payload.response;\nreturn msg;","outputs":1,"noerr":0,"x":697,"y":103,"wires":[["bd8d0057.3561f"]]},{"id":"5e27cf7c.87c67","type":"function","z":"f10a1076.cc20b","name":"Move value","func":"msg.req.query.text = \"home turn on the christmas light\"\nreturn msg;","outputs":1,"noerr":0,"x":239,"y":173,"wires":[["d86d0365.9314"]]},{"id":"1af837e2.52f558","type":"link out","z":"f10a1076.cc20b","name":"","links":["2bd7b670.60308a"],"x":856.4999694824219,"y":397.6666488647461,"wires":[]},{"id":"6c537189.6ac2d","type":"switch","z":"f10a1076.cc20b","name":"Test light?","property":"payload.command_thing","propertyType":"msg","rules":[{"t":"eq","v":"Test","vt":"str"}],"checkall":"true","outputs":1,"x":393.6666564941406,"y":465.6666564941406,"wires":[["146bb513.5434fb"]]},{"id":"146bb513.5434fb","type":"function","z":"f10a1076.cc20b","name":"Put value to payload","func":"//msg.payload = msg.payload.command_value;\nmsg.url = \"http://192.168.1.133/control?cmd=gpio,12,\"+msg.payload.command_value;\nnode.status({fill:\"blue\",shape:\"ring\",text:msg.url});\nreturn msg;","outputs":1,"noerr":0,"x":622.6666564941406,"y":466.6666564941406,"wires":[["8f969c51.fd772"]]},{"id":"8f969c51.fd772","type":"http request","z":"f10a1076.cc20b","name":"","method":"GET","ret":"txt","url":"","x":965.4999694824219,"y":465.6666488647461,"wires":[[]]}]
ebalvis
created 1 month ago
  • debug (x2)
  • function (x5)
  • http in (x1)
  • http request (x1)
  • http response (x1)
  • switch (x4)
  • link out (x1)
