Smick_006_analog_in
This flow shows the use of analog sensors (potentiometer, LDR, ...). You will learn how to configure Smick to generate:
- Measurement sequences read from the sensor;
- The LOW event when measurements fall below a certain threshold;
- The High event when measurements exceed a certain threshold. The associated dashboard allows you to:
- Enable / disable these events;
- Measurements of real-time display on a received indicator (gauge);
- Displays the last LOW / HIGH detected and sent to e-mail alarm and Twitter.
[{"id":"82283593.256f98","type":"link out","z":"c50576d5.b7af18","name":"command","links":["d00f3010.4b85b"],"x":935,"y":380,"wires":[]},{"id":"b05f8481.58d868","type":"comment","z":"c50576d5.b7af18","name":"actions on actuators","info":"","x":490,"y":320,"wires":[]},{"id":"182a53b5.e0602c","type":"comment","z":"c50576d5.b7af18","name":"actions on dashboard","info":"","x":760,"y":420,"wires":[]},{"id":"7b9c1fec.633c3","type":"e-mail","z":"c50576d5.b7af18","server":"smtp.gmail.com","port":"465","name":"[email protected]","dname":"mail","x":710,"y":720,"wires":[]},{"id":"68b0bc07.f7e484","type":"twitter out","z":"c50576d5.b7af18","twitter":"","name":"tweet","x":710,"y":780,"wires":[]},{"id":"92c8a391.39b3f","type":"comment","z":"c50576d5.b7af18","name":"actions on social","info":"","x":740,"y":660,"wires":[]},{"id":"dba2835f.b5b5d","type":"function","z":"c50576d5.b7af18","name":"alarm msg","func":"function timeDate(tz) {\n var d = new Date(Date.now()+tz*3600000);\n\n return d.getUTCHours() + \":\" +\n d.getUTCMinutes() + \":\" +\n d.getUTCSeconds() + \" \" +\n d.getUTCDate()\t+\"/\" +\n (d.getUTCMonth()+1) + \"/\" +\n d.getUTCFullYear();\n}\n\nmsg.payload=msg.payload + \" level alarm at \" + timeDate(1);\nreturn msg;","outputs":1,"noerr":0,"x":470,"y":580,"wires":[["390ea4e5.d7bf1c","38b4d5ef.66eb5a"]]},{"id":"52b00a19.992274","type":"comment","z":"c50576d5.b7af18","name":"events","info":"","x":150,"y":300,"wires":[]},{"id":"e213e6f9.afc0c8","type":"comment","z":"c50576d5.b7af18","name":"Description","info":"Questo flusso mostra l'uso di sensori analogici (Potentiometer, LDR,...).\nSi apprenderà come configurare smick per generare:\n- sequenze di misure lette dal sensore;\n- l'evento LOW quando le misure scendono al di sotto di una soglia data;\n- l'evento HIGH quando le misure superano una soglia data.\nLa dashboard associata consente di:\n- abilitare/disabilitare i suddetti eventi;\n- di visualizzare in tempo reale le misure ricevute su un indicatore (gauge);\n- di visualizzare l'ultimo allarme LOW/HIGH rilevato ed inviato su e-mail e twitter.\n\n\nThis flow shows the use of analog sensors (potentiometer, LDR, ...).\nYou will learn how to configure Smick to generate:\n- Measurement sequences read from the sensor;\n- The LOW event when measurements fall below a certain threshold;\n- The High event when measurements exceed a certain threshold.\nThe associated dashboard allows you to:\n- Enable / disable these events;\n- Measurements of real-time display on a received indicator (gauge);\n- Displays the last LOW / HIGH detected and sent to e-mail alarm and Twitter.","x":110,"y":60,"wires":[]},{"id":"d2515f8c.357ef","type":"comment","z":"c50576d5.b7af18","name":"Licence & History","info":"Package : Smick v.1\nModule : LED - digital output\nAuthor : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate Author Description\n2016.12.17 Curci genesis","x":280,"y":60,"wires":[]},{"id":"9b87b83d.556c68","type":"comment","z":"c50576d5.b7af18","name":"BOM","info":"Bill Of Material\n\nHardware:\n\n 1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n 1 Smick Wi-Fi connected to the internet\n 1 Pot | LDR + 10kohm resistor\n\nHW Connections:\n\n Device pin Smick pin\n Pot left GND\n Pot center A0\n Pot right 3.3V\n \n or \n \n Device pin Smick pin \n LDR 1 GND\n LDR 2 A0\n R 10k 1 A0\n R 10k 2 GND\n\nFlow Connections:\n\n Smick_001_console\n\nAccount:\n\n Wi-Fi credentials\n MQTT broker\n FRED\n E-mail\n Twitter\n","x":430,"y":60,"wires":[]},{"id":"16727093.2763ef","type":"link in","z":"c50576d5.b7af18","name":"else","links":["bb898c98.f25fd","dcd75773.9926a8"],"x":135,"y":580,"wires":[["390ea4e5.d7bf1c","dba2835f.b5b5d"]]},{"id":"cad53aa1.dde3e8","type":"ui_gauge","z":"c50576d5.b7af18","name":"analogic sensor","group":"7c709b15.0385b4","order":2,"width":0,"height":0,"gtype":"gage","title":"sensor","label":"","format":"{{value}}","min":0,"max":"1023","colors":["#00b500","#e6e600","#ca3838"],"x":740,"y":520,"wires":[]},{"id":"71f47e0a.f5777","type":"comment","z":"c50576d5.b7af18","name":"enable/disable","info":"","x":680,"y":200,"wires":[]},{"id":"390ea4e5.d7bf1c","type":"debug","z":"c50576d5.b7af18","name":"","active":true,"console":"false","complete":"payload","x":730,"y":840,"wires":[]},{"id":"38b4d5ef.66eb5a","type":"ui_text","z":"c50576d5.b7af18","group":"7c709b15.0385b4","order":3,"width":0,"height":0,"name":"alarm msg","label":"last alarm","format":"{{msg.payload}}","layout":"col-center","x":730,"y":580,"wires":[]},{"id":"5d74af2b.64375","type":"ui_dropdown","z":"c50576d5.b7af18","name":"","label":"mode","group":"7c709b15.0385b4","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"disable","value":"A0==NULL","type":"str"},{"label":"enable","value":"A0@1","type":"str"},{"label":"set LOW alarm","value":"LOW==A0<340","type":"str"},{"label":"set HIGH alarm","value":"HIGH==A0>680","type":"str"}],"payload":"","topic":"","x":710,"y":340,"wires":[["82283593.256f98"]]},{"id":"734b0c75.314cb4","type":"link in","z":"c50576d5.b7af18","name":"else","links":["8984e8d.24d8118"],"x":135,"y":520,"wires":[["cad53aa1.dde3e8","da035eef.f0ae6"]]},{"id":"da035eef.f0ae6","type":"debug","z":"c50576d5.b7af18","name":"","active":true,"console":"false","complete":"payload","x":730,"y":460,"wires":[]},{"id":"7c709b15.0385b4","type":"ui_group","z":"","name":"Analogic sensor","tab":"b07a13ec.60f27","order":1,"disp":true,"width":"6"},{"id":"b07a13ec.60f27","type":"ui_tab","z":"","name":"Analogic input","icon":"dashboard","order":5}]
