Smick_005_PIR_v2
This flow shows the use of a PIR sensor. You will learn how to configure Smick to generate the ALARM event when the sensor detects motion. The associated dashboard allows you to:
  • Enable / disable the said event;
  • Real-time view a received alarm;
  • Displays the last alarm detected and sent to e-mail and twitter.
[{"id":"5f462c.328339d4","type":"link out","z":"1603a5ba.b22cfa","name":"command","links":["d00f3010.4b85b"],"x":875,"y":380,"wires":[]},{"id":"df06890c.3e3848","type":"trigger","z":"1603a5ba.b22cfa","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"5","extend":true,"units":"s","reset":"","name":"","x":320,"y":520,"wires":[["114400fe.b4db3f","e083b16d.b0cc4","7cd8f38f.bccb2c"]]},{"id":"b84f0c59.2bd47","type":"comment","z":"1603a5ba.b22cfa","name":"actions on actuators","info":"","x":510,"y":320,"wires":[]},{"id":"b33eb37e.0bea9","type":"comment","z":"1603a5ba.b22cfa","name":"actions on dashboard","info":"","x":780,"y":460,"wires":[]},{"id":"3c181883.eca398","type":"e-mail","z":"1603a5ba.b22cfa","server":"smtp.gmail.com","port":"465","name":"[email protected]","dname":"mail","x":730,"y":720,"wires":[]},{"id":"a5f30042.c809c","type":"twitter out","z":"1603a5ba.b22cfa","twitter":"","name":"tweet","x":730,"y":780,"wires":[]},{"id":"377a199b.519666","type":"comment","z":"1603a5ba.b22cfa","name":"actions on social","info":"","x":760,"y":660,"wires":[]},{"id":"114400fe.b4db3f","type":"function","z":"1603a5ba.b22cfa","name":"alarm msg","func":"function timeDate(tz) {\n    var d = new Date(Date.now()+tz*3600000);\n\n    return  d.getUTCHours() + \":\" +\n            d.getUTCMinutes() + \":\" +\n            d.getUTCSeconds() + \" \" +\n            d.getUTCDate()\t+\"/\" +\n            (d.getUTCMonth()+1) + \"/\" +\n            d.getUTCFullYear();\n}\n\nmsg.payload=\"motion detected in the living room at \" +\n            timeDate(1);\nreturn msg;","outputs":1,"noerr":0,"x":510,"y":580,"wires":[["d5ab1a8b.ed5ba8","fe07f077.ee471"]]},{"id":"888f6c55.0931e","type":"comment","z":"1603a5ba.b22cfa","name":"events","info":"","x":170,"y":300,"wires":[]},{"id":"1c914744.1b3cc9","type":"comment","z":"1603a5ba.b22cfa","name":"Description","info":"Questo flusso mostra l'uso di un senore PIR.\nSi apprenderà come configurare smick per generare l'evento ALARM quando il sensore rileva un movimento.\nLa dashboard associata consente di:\n- abilitare/disabilitare il suddetto evento;\n- di visualizzare in tempo reale un allarme ricevuto;\n- di visualizzare l'ultimo allarme rilevato ed inviato su e-mail e twitter.\n\n\nThis flow shows the use of a PIR sensor.\nYou will learn how to configure Smick to generate the ALARM event when the sensor detects motion.\nThe associated dashboard allows you to:\n- Enable / disable the said event;\n- Real-time view a received alarm;\n- Displays the last alarm detected and sent to e-mail and twitter.\n","x":130,"y":60,"wires":[]},{"id":"8a9531fb.2f078","type":"comment","z":"1603a5ba.b22cfa","name":"Licence & History","info":"Package : Smick v.1\nModule  : LED - digital output\nAuthor  : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate        Author  Description\n2016.12.17  Curci   genesis","x":300,"y":60,"wires":[]},{"id":"a6a3af6e.8b597","type":"comment","z":"1603a5ba.b22cfa","name":"BOM","info":"Bill Of Material\n\nHardware:\n\n    1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n    1 Smick Wi-Fi connected to the internet\n    1 PIR\n\nHW Connections:\n\n    Device  pin     Smick pin\n    PIR     -       GND\n    PIR     out     D2\n    PIR     +       5V\n\nFlow Connections:\n\n    Smick_001_console\n\nAccount:\n\n    Wi-Fi credentials\n    MQTT broker\n    FRED\n    E-mail\n    Twitter\n","x":450,"y":60,"wires":[]},{"id":"e083b16d.b0cc4","type":"ui_gauge","z":"1603a5ba.b22cfa","name":"alarm","group":"43f2185.a7a3fe8","order":2,"width":0,"height":0,"gtype":"wave","title":"living room","label":"","format":"","min":0,"max":"1","colors":["#00b500","#e6e600","#ca3838"],"x":730,"y":520,"wires":[]},{"id":"7cd8f38f.bccb2c","type":"function","z":"1603a5ba.b22cfa","name":"internal led","func":"\nmsg.payload=\"led=\" + msg.payload;\nreturn msg;","outputs":1,"noerr":0,"x":510,"y":380,"wires":[["5f462c.328339d4"]]},{"id":"267f99af.2d3286","type":"ui_switch","z":"1603a5ba.b22cfa","name":"","label":"alarm enable","group":"43f2185.a7a3fe8","order":1,"width":0,"height":0,"passthru":true,"topic":"","style":"","onvalue":"alarm==d2=1","onvalueType":"str","onicon":"","oncolor":"","offvalue":"alarm==null","offvalueType":"str","officon":"","offcolor":"","x":690,"y":240,"wires":[["5f462c.328339d4"]]},{"id":"eb729a1.74e5568","type":"comment","z":"1603a5ba.b22cfa","name":"enable/disable","info":"","x":700,"y":200,"wires":[]},{"id":"d5ab1a8b.ed5ba8","type":"debug","z":"1603a5ba.b22cfa","name":"","active":true,"console":"false","complete":"payload","x":750,"y":840,"wires":[]},{"id":"fe07f077.ee471","type":"ui_text","z":"1603a5ba.b22cfa","group":"43f2185.a7a3fe8","order":3,"width":0,"height":0,"name":"alarm msg","label":"Last","format":"{{msg.payload}}","layout":"row-spread","x":750,"y":580,"wires":[]},{"id":"c8f76d6f.f022e","type":"link in","z":"1603a5ba.b22cfa","name":"response_event","links":["290027bd.4e4828"],"x":115,"y":420,"wires":[["5c6246da.962ec8"]]},{"id":"5c6246da.962ec8","type":"switch","z":"1603a5ba.b22cfa","name":"parse","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"ALARM","vt":"str"}],"checkall":"false","outputs":1,"x":230,"y":420,"wires":[["df06890c.3e3848"]]},{"id":"43f2185.a7a3fe8","type":"ui_group","z":"","name":"PIR alarm","tab":"7482d054.817ee","order":1,"disp":false,"width":"6"},{"id":"7482d054.817ee","type":"ui_tab","z":"","name":"PIR alarm","icon":"dashboard","order":4}]
Created 7 years, 11 months ago
  • comment (x8)
  • function (x2)
  • link in (x1)
  • link out (x1)
  • switch (x1)
  • trigger (x1)
  • e-mail (x1)
  • twitter out (x1)
  • ui_gauge (x1)
  • ui_group (x1)
  • ui_switch (x1)
  • ui_text (x1)
  • Smick
  • iot
