System Information Dashboard
Dashboard UI for viewing host machine system information based on node-red-dashboard and node-red-contrib-os. Includes CPU, Memory & other info.
UI Preview
alt text
alt text
[{"id":"772e6979.67cd08","type":"tab","label":"System"},{"id":"f25a9b1d.c6fce8","type":"OS","z":"772e6979.67cd08","name":"","x":234,"y":398,"wires":[["f745cace.30f2d8","3153bd68.82b782","7eec4b7e.c15ad4","6b4d7f76.271fb"]]},{"id":"c63cb373.ce94f","type":"Uptime","z":"772e6979.67cd08","name":"","x":245,"y":353,"wires":[["20567afa.bd4466"]]},{"id":"21faa622.8c25da","type":"CPUs","z":"772e6979.67cd08","name":"","x":234,"y":443,"wires":[["8a945e71.8626b"]]},{"id":"7780c9ca.7581b8","type":"Loadavg","z":"772e6979.67cd08","name":"","x":171,"y":165,"wires":[["240a76f3.9953ea","5d85387c.957fb8","b33d4d45.a6673","a25b88bc.6ead88"]]},{"id":"7cf01d46.a3cad4","type":"Memory","z":"772e6979.67cd08","name":"","x":111,"y":531,"wires":[["e6b8a679.aff648","dd0cca19.6f90a8","308d683f.10ab08","fbd3e7db.8ca558"]]},{"id":"ed27cae4.70b728","type":"inject","z":"772e6979.67cd08","name":"update","topic":"","payload":"","payloadType":"date","repeat":"30","crontab":"","once":true,"x":94,"y":245,"wires":[["f25a9b1d.c6fce8","c63cb373.ce94f","21faa622.8c25da","7780c9ca.7581b8","7cf01d46.a3cad4"]]},{"id":"240a76f3.9953ea","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.loadavg[0];\nreturn msg;","outputs":1,"noerr":0,"x":333,"y":105,"wires":[["51dfac0c.fdc9c4"]]},{"id":"5d85387c.957fb8","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.loadavg[1];\nreturn msg;","outputs":1,"noerr":0,"x":334,"y":143,"wires":[["79d3dbc8.390014"]]},{"id":"b33d4d45.a6673","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.loadavg[2];\nreturn msg;","outputs":1,"noerr":0,"x":333,"y":186,"wires":[["1ff0080f.4e10c8"]]},{"id":"51dfac0c.fdc9c4","type":"ui_gauge","z":"772e6979.67cd08","name":"CPU Load 1","group":"7853403.230cdc","order":1,"width":"0","height":"0","gtype":"gage","title":"1 Minute","label":"load","format":"{{value | number:2}}","min":0,"max":"4","colors":["#00b500","#e6e600","#ca3838"],"x":501,"y":104,"wires":[]},{"id":"79d3dbc8.390014","type":"ui_gauge","z":"772e6979.67cd08","name":"CPU Load 2","group":"7853403.230cdc","order":2,"width":"3","height":"3","gtype":"gage","title":"5 Minutes","label":"load","format":"{{value | number:2}}","min":0,"max":"4","colors":["#00b500","#e6e600","#ca3838"],"x":501,"y":145,"wires":[]},{"id":"1ff0080f.4e10c8","type":"ui_gauge","z":"772e6979.67cd08","name":"CPU Load 3","group":"7853403.230cdc","order":4,"width":"3","height":"3","gtype":"gage","title":"15 Minutes","label":"load","format":"{{value | number:2}}","min":0,"max":"4","colors":["#00b500","#e6e600","#ca3838"],"x":499,"y":187,"wires":[]},{"id":"e6b8a679.aff648","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.memusage;\nreturn msg;","outputs":1,"noerr":0,"x":116,"y":699,"wires":[["cc57cdea.f9387"]]},{"id":"cc57cdea.f9387","type":"ui_gauge","z":"772e6979.67cd08","name":"Memory Usage","group":"1d1da0fc.6ab84f","order":1,"width":"0","height":"0","gtype":"gage","title":"1 Minute","label":"Usage","format":"{{value | number:2}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"x":300,"y":703,"wires":[]},{"id":"dd0cca19.6f90a8","type":"function","z":"772e6979.67cd08","name":"","func":"function formatBytes(bytes,decimals) {\n   if(bytes === 0) return '0 Byte';\n   var k = 1000; // or 1024 for binary\n   var dm = decimals + 1 || 3;\n   var sizes = ['Bytes', 'KB', 'MB', 'GB', 'TB', 'PB', 'EB', 'ZB', 'YB'];\n   var i = Math.floor(Math.log(bytes) / Math.log(k));\n   return parseFloat((bytes / Math.pow(k, i)).toFixed(dm)) + ' ' + sizes[i];\n}\n\nmsg.payload = formatBytes(msg.payload.totalmem);\nreturn msg;","outputs":1,"noerr":0,"x":118,"y":742,"wires":[["4aeaebd1.24f4c4"]]},{"id":"308d683f.10ab08","type":"function","z":"772e6979.67cd08","name":"","func":"function formatBytes(bytes,decimals) {\n   if(bytes === 0) return '0 Byte';\n   var k = 1000; // or 1024 for binary\n   var dm = decimals + 1 || 3;\n   var sizes = ['Bytes', 'KB', 'MB', 'GB', 'TB', 'PB', 'EB', 'ZB', 'YB'];\n   var i = Math.floor(Math.log(bytes) / Math.log(k));\n   return parseFloat((bytes / Math.pow(k, i)).toFixed(dm)) + ' ' + sizes[i];\n}\n\nmsg.payload = formatBytes(msg.payload.freemem);\nreturn msg;","outputs":1,"noerr":0,"x":116,"y":788,"wires":[["ef649e9b.dce7d"]]},{"id":"4aeaebd1.24f4c4","type":"ui_text","z":"772e6979.67cd08","group":"1d1da0fc.6ab84f","order":2,"width":"0","height":"0","name":"","label":"Total Memory","format":"{{msg.payload}}","layout":"row-spread","x":299,"y":746,"wires":[]},{"id":"ef649e9b.dce7d","type":"ui_text","z":"772e6979.67cd08","group":"1d1da0fc.6ab84f","order":3,"width":"0","height":"0","name":"","label":"Free Memory","format":"{{msg.payload}}","layout":"row-spread","x":303,"y":789,"wires":[]},{"id":"20567afa.bd4466","type":"function","z":"772e6979.67cd08","name":"","func":"function timeConversion(millisec) {\n\n    var seconds = (millisec / 1000).toFixed(1);\n\n    var minutes = (millisec / (1000 * 60)).toFixed(1);\n\n    var hours = (millisec / (1000 * 60 * 60)).toFixed(1);\n\n    var days = (millisec / (1000 * 60 * 60 * 24)).toFixed(1);\n\n    if (seconds < 60) {\n        return seconds + \" Sec\";\n    } else if (minutes < 60) {\n        return minutes + \" Min\";\n    } else if (hours < 24) {\n        return hours + \" Hrs\";\n    } else {\n        return days + \" Days\"\n    }\n}\n\nmsg.payload = timeConversion(msg.payload.uptime * 1000);\nreturn msg;","outputs":1,"noerr":0,"x":406,"y":353,"wires":[["91bb24ba.6dba48"]]},{"id":"91bb24ba.6dba48","type":"ui_text","z":"772e6979.67cd08","group":"a9912d64.97094","order":1,"width":"0","height":"0","name":"","label":"Uptime","format":"{{msg.payload}}","layout":"row-spread","x":561,"y":352,"wires":[]},{"id":"f745cace.30f2d8","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.hostname;\nreturn msg;","outputs":1,"noerr":0,"x":405,"y":390,"wires":[["f9bfd652.4be908"]]},{"id":"f9bfd652.4be908","type":"ui_text","z":"772e6979.67cd08","group":"a9912d64.97094","order":1,"width":"0","height":"0","name":"","label":"Hostname","format":"{{msg.payload}}","layout":"row-spread","x":573,"y":392,"wires":[]},{"id":"3153bd68.82b782","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.platform;\nreturn msg;","outputs":1,"noerr":0,"x":407,"y":428,"wires":[["6c7dc269.a0180c"]]},{"id":"6c7dc269.a0180c","type":"ui_text","z":"772e6979.67cd08","group":"a9912d64.97094","order":1,"width":"0","height":"0","name":"","label":"Platform","format":"{{msg.payload}}","layout":"row-spread","x":569,"y":431,"wires":[]},{"id":"7eec4b7e.c15ad4","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.arch;\nreturn msg;","outputs":1,"noerr":0,"x":408,"y":467,"wires":[["a6e5bcd3.7c90e"]]},{"id":"a6e5bcd3.7c90e","type":"ui_text","z":"772e6979.67cd08","group":"a9912d64.97094","order":1,"width":"0","height":"0","name":"","label":"Arch","format":"{{msg.payload}}","layout":"row-spread","x":557,"y":471,"wires":[]},{"id":"6b4d7f76.271fb","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.release;\nreturn msg;","outputs":1,"noerr":0,"x":409,"y":503,"wires":[["f7e2d4a1.f3acf8"]]},{"id":"f7e2d4a1.f3acf8","type":"ui_text","z":"772e6979.67cd08","group":"a9912d64.97094","order":1,"width":"0","height":"0","name":"","label":"Release","format":"{{msg.payload}}","layout":"row-spread","x":569,"y":509,"wires":[]},{"id":"8a945e71.8626b","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.cpus[0].model;\nreturn msg;","outputs":1,"noerr":0,"x":408,"y":544,"wires":[["6ce3fe6a.0088f","6ed6930f.dfaa0c","2cf68a4b.2caef6","6ad00145.d0875"]]},{"id":"6ce3fe6a.0088f","type":"ui_text","z":"772e6979.67cd08","group":"a9912d64.97094","order":1,"width":"0","height":"0","name":"","label":"CPU 1","format":"{{msg.payload}}","layout":"row-spread","x":560,"y":552,"wires":[]},{"id":"6ed6930f.dfaa0c","type":"ui_text","z":"772e6979.67cd08","group":"a9912d64.97094","order":1,"width":"0","height":"0","name":"","label":"CPU 2","format":"{{msg.payload}}","layout":"row-spread","x":562,"y":591,"wires":[]},{"id":"2cf68a4b.2caef6","type":"ui_text","z":"772e6979.67cd08","group":"a9912d64.97094","order":1,"width":"0","height":"0","name":"","label":"CPU 3","format":"{{msg.payload}}","layout":"row-spread","x":564,"y":632,"wires":[]},{"id":"6ad00145.d0875","type":"ui_text","z":"772e6979.67cd08","group":"a9912d64.97094","order":1,"width":"0","height":"0","name":"","label":"CPU 4","format":"{{msg.payload}}","layout":"row-spread","x":566,"y":672,"wires":[]},{"id":"a25b88bc.6ead88","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.loadavg[0];\nreturn msg;","outputs":1,"noerr":0,"x":338,"y":229,"wires":[["a978ef7f.6851a"]]},{"id":"a978ef7f.6851a","type":"ui_chart","z":"772e6979.67cd08","name":"CPU Load - Historical","group":"7853403.230cdc","order":0,"width":"0","height":"0","label":"24 Hours","chartType":"line","legend":"false","xformat":"%H:%M:%S","interpolate":"linear","nodata":"","ymin":"","ymax":"","removeOlder":1,"removeOlderUnit":"86400","x":530,"y":229,"wires":[[],[]]},{"id":"fbd3e7db.8ca558","type":"function","z":"772e6979.67cd08","name":"","func":"msg.payload = msg.payload.memusage;\nreturn msg;","outputs":1,"noerr":0,"x":113,"y":660,"wires":[["ae72c338.cf1ff"]]},{"id":"ae72c338.cf1ff","type":"ui_chart","z":"772e6979.67cd08","name":"Memory - 24 Hours","group":"1d1da0fc.6ab84f","order":0,"width":"0","height":"0","label":"24 Hours","chartType":"line","legend":"false","xformat":"%H:%M:%S","interpolate":"linear","nodata":"","ymin":"","ymax":"","removeOlder":1,"removeOlderUnit":"86400","x":311,"y":663,"wires":[[],[]]},{"id":"6d8c1a68.736494","type":"comment","z":"772e6979.67cd08","name":"CPU Load","info":"","x":488,"y":57,"wires":[]},{"id":"c759448a.854258","type":"comment","z":"772e6979.67cd08","name":"Memory Usage","info":"","x":296,"y":613,"wires":[]},{"id":"ff2b3794.382148","type":"comment","z":"772e6979.67cd08","name":"System Information","info":"","x":587,"y":302,"wires":[]},{"id":"7853403.230cdc","type":"ui_group","z":"","name":"CPU Load","tab":"e6013c6f.69328","order":2,"disp":true,"width":"6"},{"id":"1d1da0fc.6ab84f","type":"ui_group","z":"","name":"Memory","tab":"e6013c6f.69328","order":3,"disp":true,"width":"6"},{"id":"a9912d64.97094","type":"ui_group","z":"","name":"System Information","tab":"e6013c6f.69328","order":1,"disp":true,"width":"6"},{"id":"e6013c6f.69328","type":"ui_tab","z":"","name":"System","icon":"computer"}]
Created 10 years, 9 months ago
Updated 7 years, 7 months ago
Rating: 5 5
  • comment (x3)
  • function (x14)
  • CPUs (x1)
  • Loadavg (x1)
  • Memory (x1)
  • OS (x1)
  • Uptime (x1)
  • ui_chart (x2)
  • ui_gauge (x4)
  • ui_group (x3)
  • ui_text (x11)
  • dashboard
  • sysinfo
  • ui
  • load
  • cpu
  • memory
  • system
  • information
  • visual
  • node-red-dashboard
  • node-red-contrib-os
