Intensity Philips Hue
This allows users to set the intensity and color of Philips Hue lamps quickly and easily.
In the case of addition of luminance sensors, it allows the automatic control.
[{"id":"c1466b39.ce5f3","type":"Hue Pull","z":"8dc7773.58cca08","deviceid":"2","serverid":"001788fffe16dd0a","name":"Lamp1","x":896.5,"y":385.5,"wires":[["ef1b52ec.f32738"],[]]},{"id":"ef1b52ec.f32738","type":"debug","z":"8dc7773.58cca08","name":"","active":true,"console":false,"complete":"payload","x":1056,"y":302.5,"wires":[]},{"id":"d47b4bb4.6f7fa8","type":"function","z":"8dc7773.58cca08","name":"on","func":"msg.payload={\n\t\"on\":[true],\n\t\"bri\":[255],\n\t\"rgb\":[255,255,255]\n};\nreturn msg;","outputs":1,"noerr":0,"x":409,"y":361.5,"wires":[["9ac98c2e.a37cb"]]},{"id":"1886916c.dfd14f","type":"function","z":"8dc7773.58cca08","name":"off","func":"msg.payload={\n\t\"on\":[false],\n\n};\nreturn msg;","outputs":1,"noerr":0,"x":409,"y":415.5,"wires":[["9ac98c2e.a37cb"]]},{"id":"9ac98c2e.a37cb","type":"Hue Set","z":"8dc7773.58cca08","deviceid":"2","serverid":"001788fffe16dd0a","name":"Lamp1","x":688,"y":382.75,"wires":[["c1466b39.ce5f3"],[]]},{"id":"f575dc9c.20bfe8","type":"ui_button","z":"8dc7773.58cca08","name":"ON","group":"82bfa00d.f6e7b","order":1,"width":"0","height":"0","label":"ON","color":"","bgcolor":"green","icon":"","payload":"1","payloadType":"str","topic":"","x":172,"y":360,"wires":[["d47b4bb4.6f7fa8"]]},{"id":"756b7166.3c6f6","type":"ui_button","z":"8dc7773.58cca08","name":"OFF","group":"82bfa00d.f6e7b","order":2,"width":"0","height":"0","label":"OFF","color":"","bgcolor":"red","icon":"","payload":"0","payloadType":"str","topic":"","x":177,"y":414,"wires":[["1886916c.dfd14f"]]},{"id":"d4e5bd59.c156a","type":"ui_slider","z":"8dc7773.58cca08","name":"Brightness","label":"Intensidade","group":"2d12474c.4621f","order":3,"width":"0","height":"0","passthru":true,"topic":"","min":0,"max":"255","step":1,"x":189.5,"y":302.5,"wires":[["1ff12168.9d874f"]]},{"id":"1ff12168.9d874f","type":"function","z":"8dc7773.58cca08","name":"set_intensity","func":"var test= msg.payload;\n\nmsg.payload={\n\t\"bri\":[test]\n};\n\nreturn msg;","outputs":1,"noerr":0,"x":409,"y":302,"wires":[["9ac98c2e.a37cb"]]},{"id":"1c04f89d.e51b8f","type":"ui_colour_picker","z":"8dc7773.58cca08","name":"","label":"Color","group":"2d12474c.4621f","format":"rgb","outformat":"string","showSwatch":true,"showPicker":false,"showValue":false,"showAlpha":true,"order":4,"width":0,"height":0,"passthru":true,"topic":"","x":171,"y":243,"wires":[["d16fe22e.5a455"]]},{"id":"d16fe22e.5a455","type":"function","z":"8dc7773.58cca08","name":"set_color","func":"var cor= msg.payload;\n\nmsg.payload={\n\t\"rgb\":[cor]\n};\n\nreturn msg;","outputs":1,"noerr":0,"x":405.5,"y":244.5,"wires":[["9ac98c2e.a37cb"]]},{"id":"82bfa00d.f6e7b","type":"ui_group","z":"baa229bc.af9318","name":"Iluminação Mesa 2","tab":"3fc04bb1.bd1d0c","order":3,"disp":true,"width":"6"},{"id":"2d12474c.4621f","type":"ui_group","z":"","name":"Iluminação Mesa 1","tab":"3fc04bb1.bd1d0c","order":2,"disp":true,"width":"6"},{"id":"3fc04bb1.bd1d0c","type":"ui_tab","z":"","name":"Iluminação Sala","icon":"dashboard","order":1}]
tqpessoa
created 3 months ago
  • function (x4)
  • Hue Pull (x1)
  • Hue Set (x1)
  • ui_button (x2)
  • ui_colour_picker (x1)
  • ui_group (x2)
  • ui_slider (x1)
  • ui
  • function
  • hue
