Smick_002_LED_digital
This flow builds a dashboard that contains a switch node to switch on or off the LED. The generated commands are sent to Smick through "dasboard console" flow".
[{"id":"e192fa90.cfab68","type":"ui_switch","z":"5ce9b4ba.37af7c","name":"","label":"Off/On","group":"5e36b7c5.bef018","order":1,"width":0,"height":0,"passthru":false,"topic":"","style":"","onvalue":"d8=0","onvalueType":"str","onicon":"","oncolor":"","offvalue":"d8=1","offvalueType":"str","officon":"","offcolor":"","x":150,"y":260,"wires":[["76792d1c.717924"]]},{"id":"76792d1c.717924","type":"link out","z":"5ce9b4ba.37af7c","name":"command","links":["d00f3010.4b85b"],"x":375,"y":260,"wires":[]},{"id":"bf91673.1e8b498","type":"comment","z":"5ce9b4ba.37af7c","name":"digital output","info":"","x":150,"y":160,"wires":[]},{"id":"6eea49a3.ec6ec8","type":"comment","z":"5ce9b4ba.37af7c","name":"Description","info":"Questo flusso costruisce un cruscotto contenente un nodo switch per accendere o spegnere il LED.\nI comandi generati sono inviati a smick tramite il flusso \"dasboard console\".\n\nThis flow builds a dashboard that contains a switch node to switch on or off the LED.\nThe generated commands are sent to Smick through \"dasboard console\" flow\".","x":150,"y":40,"wires":[]},{"id":"f627b018.2b69f","type":"comment","z":"5ce9b4ba.37af7c","name":"Licence & History","info":"Package : Smick v.1\nModule : LED - digital output\nAuthor : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate Author Description\n2016.12.17 Curci genesis","x":320,"y":40,"wires":[]},{"id":"e6a90fb.c1455f","type":"comment","z":"5ce9b4ba.37af7c","name":"BOM","info":"Bill Of Material\n\nHardware:\n\n 1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n 1 Smick Wi-Fi connected to the internet\n 1 LED connected to smick \n\nHW Connections:\n\n Device pin Smick pin\n LED + 3.3V\n LED - D8\n\nFlow Connections:\n\n Smick_001_console\n\nAccount:\n\n Wi-Fi credentials\n MQTT broker\n FRED\n","x":470,"y":40,"wires":[]},{"id":"5e36b7c5.bef018","type":"ui_group","z":"","name":"LED","tab":"9f185bbc.98cc78","order":1,"disp":true,"width":"6"},{"id":"9f185bbc.98cc78","type":"ui_tab","z":"","name":"LED","icon":"dashboard","order":2}]
