Flow Electric Multimeter
Allows users who use ISSO Tecnologia's electric multimeter to perform power readings in each phase and store in the application.
[{"id":"535b7881.22b618","type":"inject","z":"3d6d7292.933c8e","name":"","topic":"","payload":"","payloadType":"date","repeat":"1200","crontab":"","once":true,"x":380.5,"y":305.66668701171875,"wires":[["6df54715.dd9d8","db1efecd.1c557","9b746c87.3f75e8"]]},{"id":"6df54715.dd9d8","type":"http request","z":"3d6d7292.933c8e","name":"GET_Medidor_Fase2","method":"GET","ret":"txt","url":"ip_do_medidor/sistema.cgi?lermc=32,1","tls":"","x":656.9443969726562,"y":306.6666564941406,"wires":[["6d11b35.5e0e04c"]]},{"id":"db1efecd.1c557","type":"http request","z":"3d6d7292.933c8e","name":"GET_Medidor_Fase1","method":"GET","ret":"txt","url":"ip_do_medidor/sistema.cgi?lermc=22,1","tls":"","x":654.7222290039062,"y":391.25,"wires":[["58f63394.8875c4"]]},{"id":"9b746c87.3f75e8","type":"http request","z":"3d6d7292.933c8e","name":"GET_Medidor_Fase3","method":"GET","ret":"txt","url":"ip_do_medidor/sistema.cgi?lermc=42,1","tls":"","x":654.7222290039062,"y":470,"wires":[["bd3c86a1.3a91f"]]},{"id":"6d11b35.5e0e04c","type":"http request","z":"3d6d7292.933c8e","name":"Writer_BD_Pt_Fase2","method":"GET","ret":"txt","url":"Address_Server_BD","tls":"","x":1032.2222290039062,"y":303.75,"wires":[[]]},{"id":"58f63394.8875c4","type":"http request","z":"3d6d7292.933c8e","name":"Writer_BD_Pt_Fase1","method":"GET","ret":"txt","url":"Address_Server_BD","tls":"","x":1035.0000610351562,"y":388.3333435058594,"wires":[[]]},{"id":"bd3c86a1.3a91f","type":"http request","z":"3d6d7292.933c8e","name":"Writer_BD_Pt_Fase3","method":"GET","ret":"txt","url":"Address_Server_BD","tls":"","x":1030.0000610351562,"y":467.0833435058594,"wires":[[]]},{"id":"9649fdb7.ae5228","type":"http request","z":"3d6d7292.933c8e","name":"Writer_BD_Pt_Mensal","method":"GET","ret":"txt","url":"Address_Server_BD","tls":"","x":1021.6944580078125,"y":577.5833129882812,"wires":[[]]},{"id":"f7578a41.9a8be8","type":"comment","z":"3d6d7292.933c8e","name":"Envio de dados do medidor para Web","info":"","x":462.22222900390625,"y":165,"wires":[]},{"id":"97d56256.f92f58","type":"http request","z":"3d6d7292.933c8e","name":"GET_Medidor_Cons_Mes","method":"GET","ret":"txt","url":"ip_do_medidor/sistema.cgi?lermc=59,1","tls":"","x":666.4166259765625,"y":580.4999694824219,"wires":[["9649fdb7.ae5228"]]},{"id":"c75f9f30.859598","type":"inject","z":"3d6d7292.933c8e","name":"","topic":"","payload":"","payloadType":"date","repeat":"86400","crontab":"","once":true,"x":369.97222900390625,"y":579.5,"wires":[["97d56256.f92f58"]]}]
tqpessoa
created 3 months ago
  • http request (x8)
  • inject (x2)
  • Electric
  • power
  • ISSO
