Smick_04_analogic_output
Analogic output (PWM) example
[{"id":"8687af10.572f9","type":"tab","label":"analogic_output"},{"id":"490bf569.5df81c","type":"ui_slider","z":"8687af10.572f9","name":"","label":"D2 PWM","group":"9afd09b1.9a0ca8","order":2,"width":0,"height":0,"passthru":true,"topic":"","min":"0","max":"100","step":"1","x":220,"y":340,"wires":[["39c62157.e0b85e"]]},{"id":"2b8ff9bd.7a7ec6","type":"link out","z":"8687af10.572f9","name":"command","links":["1096456f.bfc93b"],"x":775,"y":340,"wires":[]},{"id":"b2d27b1b.4fa508","type":"function","z":"8687af10.572f9","name":"D2=n","func":"msg.payload=\"d2=\"+msg.payload;\nreturn msg;","outputs":1,"noerr":0,"x":650,"y":340,"wires":[["2b8ff9bd.7a7ec6"]]},{"id":"39c62157.e0b85e","type":"range","z":"8687af10.572f9","minin":"0","maxin":"100","minout":"0","maxout":"1023","action":"scale","round":true,"name":"0..1023","x":420,"y":340,"wires":[["b2d27b1b.4fa508"]]},{"id":"d0a2ad0b.1ec3b","type":"comment","z":"8687af10.572f9","name":"analogic output (PWM)","info":"","x":260,"y":240,"wires":[]},{"id":"8e3013c5.d98f3","type":"comment","z":"8687af10.572f9","name":"Description","info":"Smick_04_analogic_output\n_______________________________________________________________________________\nPackage : Smick v.1\nModule  : console\nAuthor  : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate        Author  Description\n2016.12.17  Curci   genesis\n_______________________________________________________________________________\n\nDescription\n\nQuesto flusso costruisce un cruscotto contenente un nodo slider per regolare la luminosità del LED.\nI comandi generati sono inviati a smick tramite il flusso \"dasboard console\".\n\nThis flow builds a dashboard that contains a slider node to regulate the LED brightness.\nThe generated commands are sent to Smick through \"dasboard console\" flow\".\n_______________________________________________________________________________\n\nBill Of Material\n\nHardware:\n\n    1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n    1 Smick Wi-Fi connected to the internet\n    1 LED connected to smick \n\nHW Connections:\n\n    Device  pin     Smick pin\n    LED     +       D2\n    LED     -       GND\n\nFlow Connections:\n\n    console\n\nAccount:\n\n    Wi-Fi credentials\n    MQTT broker\n    FRED\n","x":220,"y":140,"wires":[]},{"id":"9afd09b1.9a0ca8","type":"ui_group","z":"","name":"analogic","tab":"f142a68c.ec9b78","order":2,"disp":true,"width":"6"},{"id":"f142a68c.ec9b78","type":"ui_tab","z":"","name":"Output","icon":"dashboard","order":2}]
Created 7 years, 11 months ago
  • comment (x2)
  • link out (x1)
  • range (x1)
  • ui_group (x1)
  • ui_slider (x1)
