Smick_004_button_v8
Digital button D3
        "id": "cb252ff.0027dd",
        "type": "subflow",
        "name": "Smick status",
        "info": "Detect Smick connection status.",
        "in": [
                "x": 320,
                "y": 460,
                        "id": "5420ceb4.ac018"
        "out": [
                "x": 760,
                "y": 400,
                        "id": "4bf018ec.09c848",
                        "port": 0
        "id": "bceacaa7.47fc78",
        "type": "ui_text",
        "z": "cb252ff.0027dd",
        "group": "f4652c38.539e6",
        "order": 0,
        "width": 0,
        "height": 0,
        "label": "status: ",
        "format": "{{msg.payload}}",
        "layout": "row-center",
        "x": 830,
        "y": 460,
        "id": "5420ceb4.ac018",
        "type": "switch",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "DISC",
                "vt": "str"
                "t": "else"
        "checkall": "true",
        "outputs": 2,
        "x": 450,
        "y": 460,
                "a223a590.72dbf8",
                "4bf018ec.09c848"
                "59f39fd5.4b1f5"
        "id": "a223a590.72dbf8",
        "type": "change",
        "name": "disconnected",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "disconnected",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 650,
        "y": 460,
                "bceacaa7.47fc78"
        "id": "59f39fd5.4b1f5",
        "type": "change",
        "name": "connected",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "connected",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 650,
        "y": 520,
                "bceacaa7.47fc78"
        "type": "change",
        "name": "PING",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "PING",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 630,
        "y": 400,
        "id": "f4652c38.539e6",
        "type": "ui_group",
        "z": "",
        "name": "console",
        "tab": "9c0e486b.51b0c8",
        "order": 1,
        "disp": true,
        "width": "6"
        "id": "9c0e486b.51b0c8",
        "type": "ui_tab",
        "z": "",
        "name": "Console",
        "icon": "dashboard",
        "order": 1
        "id": "8c17b331.cd1c7",
        "type": "subflow",
        "name": "Smick event",
        "info": "Receive command responses or events from Smick.",
        "in": [],
        "out": [
                "x": 660,
                "y": 180,
                        "id": "1db2fb61.81a135",
                        "port": 0
        "id": "9e9bef70.383b9",
        "type": "ui_text",
        "z": "8c17b331.cd1c7",
        "order": 2,
        "width": "0",
        "height": "0",
        "label": "response/event",
        "layout": "col-center",
        "x": 460,
        "y": 240,
        "type": "mqtt in",
        "name": "mqtt res/eve",
        "topic": "borot/feeds/O3300460880",
        "qos": "0",
        "broker": "f1f7b732.115e58",
        "x": 210,
        "y": 180,
                "9e9bef70.383b9",
                "c9ca8862.893398"
        "id": "c9ca8862.893398",
        "type": "debug",
        "name": "response/event",
        "active": true,
        "console": "false",
        "complete": "payload",
        "x": 460,
        "y": 120,
        "type": "ui_group",
        "z": "",
        "name": "console",
        "order": 1,
        "disp": true,
        "width": "6"
        "id": "f1f7b732.115e58",
        "type": "mqtt-broker",
        "z": "",
        "broker": "io.adafruit.com",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "compatmode": true,
        "keepalive": "300",
        "cleansession": true,
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": ""
        "type": "ui_tab",
        "z": "",
        "name": "Console",
        "order": 1
        "id": "227e1b69.92def4",
        "type": "subflow",
        "name": "Smick command",
        "info": "Send commands to Smick.",
        "in": [
                "x": 160,
                "y": 120,
                        "id": "7b0b44fa.5ea32c"
        "out": []
        "id": "175720.d53688e",
        "type": "mqtt out",
        "z": "227e1b69.92def4",
        "name": "smick cmd",
        "topic": "borot/feeds/I3300460880",
        "qos": "0",
        "retain": "true",
        "x": 610,
        "y": 160,
        "id": "1408ce46.5b1292",
        "type": "debug",
        "name": "command",
        "active": true,
        "console": "false",
        "x": 600,
        "y": 80,
        "id": "7b0b44fa.5ea32c",
        "type": "ui_text_input",
        "label": "command",
        "order": 1,
        "width": "0",
        "height": "0",
        "passthru": true,
        "mode": "text",
        "delay": "0",
        "topic": "",
        "x": 360,
        "y": 120,
                "175720.d53688e",
                "1408ce46.5b1292"
        "id": "f9226ee3.6cc58",
        "type": "comment",
        "name": "Description",
        "info": "Smick_001_console_v4\n_______________________________________________________________________________\nPackage : Smick v.1\nModule  : console\nAuthor  : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate        Author  Description\n2016.12.26  Curci   genesis\n_______________________________________________________________________________\n\nDescription\n\nQuesto flusso costruisce un cruscotto console per interagire con smick tramite feed mqtt.\nSi possono inviare comandi sul feed di input di smick e ricevere risposte o eventi dal feed di output di smick.\nContiene inoltre un nodo link di input per consentire ad altri flussi l'invio di comandi e un nodo link di output per smistare risposte/eventi ricevuti ad altri flussi.\nInfine i messaggi inviati e le risposte / eventi ricevuti sono elencati su debug tab mediante nodi debug.\n\n\nThis flow builds a dashboard console to interact with Smick through MQTT feed.\nYou can send commands on Smick input feed and receive answers or events from Smick output feed.\nIt also contains an input node link to allow other flows sending commands and an output node link to direct responses / events received to other flows.\nFinally sent messages and replies / received events are listed on debug tab using debug nodes.\n\n_______________________________________________________________________________\n\nBill Of Material\n\nHardware:\n\n    1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n    1 Smick Wi-Fi connected to the internet\n\nHW Connections:\n\n    None.\n\nFlow Connections:\n\n    None\n\nAccount:\n\n    Wi-Fi router\n    MQTT broker\n    FRED\n",
        "x": 140,
        "y": 40,
        "z": "",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "compatmode": true,
        "keepalive": "300",
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": ""
        "type": "ui_group",
        "z": "",
        "name": "console",
        "order": 1,
        "disp": true,
        "width": "6"
        "type": "ui_tab",
        "z": "",
        "name": "Console",
        "order": 1
        "id": "595fac32.0e1834",
        "type": "subflow:227e1b69.92def4",
        "z": "4913b9c6.f83e88",
        "x": 1100,
        "y": 340,
        "id": "9d0cc56c.2cac98",
        "type": "subflow:8c17b331.cd1c7",
        "x": 130,
        "y": 340,
                "8d1c78c2.cec9b8",
                "1e044ae2.090ee5"
        "id": "8d1c78c2.cec9b8",
        "type": "subflow:cb252ff.0027dd",
        "x": 390,
        "y": 340,
                "595fac32.0e1834"
        "id": "145352da.415a9d",
        "type": "ui_switch",
        "name": "off/on",
        "label": "off/on",
        "group": "2fb4e76.9ec5c18",
        "order": 0,
        "width": 0,
        "height": 0,
        "passthru": true,
        "topic": "",
        "style": "",
        "onvalue": "LED=1",
        "onvalueType": "str",
        "onicon": "",
        "oncolor": "",
        "offvalue": "LED=0",
        "offvalueType": "str",
        "officon": "",
        "offcolor": "",
        "x": 370,
        "y": 100,
                "595fac32.0e1834"
        "id": "abf7be6f.84a3c",
        "type": "ui_button",
        "name": "off",
        "order": 0,
        "width": "3",
        "height": "1",
        "label": "off",
        "color": "",
        "icon": "",
        "payload": "D3=0",
        "payloadType": "str",
        "topic": "",
        "x": 370,
        "y": 160,
                "595fac32.0e1834"
        "id": "b6cb664a.7e5c48",
        "name": "on",
        "order": 0,
        "width": "3",
        "height": "1",
        "label": "on",
        "color": "",
        "icon": "",
        "payload": "D3=0;D3=1",
        "topic": "",
        "x": 370,
        "y": 220,
                "595fac32.0e1834"
        "id": "9ea37929.b1e6b8",
        "type": "ui_slider",
        "label": "analogic",
        "group": "9b895ead.8e0b9",
        "order": 0,
        "width": 0,
        "height": 0,
        "passthru": true,
        "topic": "",
        "min": 0,
        "max": "1023",
        "step": "10",
        "x": 380,
        "y": 280,
                "34e289b4.1150a6"
        "id": "34e289b4.1150a6",
        "type": "function",
        "name": "D3=n",
        "func": "\nmsg.payload=\"D3=\"+msg.payload\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 530,
        "y": 280,
                "595fac32.0e1834"
        "id": "5dd05f78.759f3",
        "type": "trigger",
        "op1": "LED=1",
        "op2": "LED=0",
        "op1type": "str",
        "op2type": "str",
        "duration": "3",
        "extend": false,
        "units": "s",
        "reset": "",
        "name": "led on 5sec",
        "x": 590,
        "y": 760,
                "595fac32.0e1834"
        "id": "10dd847e.0b60bc",
        "type": "function",
        "name": "setup",
        "func": "\nmsg.payload=\"click==d3=0\";\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 450,
        "y": 620,
                "715a9ee0.f0026"
        "id": "1d6090f6.3810bf",
        "type": "ui_gauge",
        "name": "Button",
        "group": "9488c7a0.65a508",
        "order": 2,
        "width": "2",
        "height": "2",
        "gtype": "donut",
        "title": "",
        "label": "click",
        "format": "{{value}}",
        "min": 0,
        "max": "1",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "x": 810,
        "y": 860,
        "id": "c077af9f.b1d4",
        "type": "ui_chart",
        "name": "click",
        "order": 3,
        "width": 0,
        "height": 0,
        "label": "",
        "chartType": "line",
        "legend": "false",
        "xformat": "%H:%M:%S",
        "interpolate": "step-after",
        "nodata": "push switch",
        "ymin": "0",
        "ymax": "1",
        "removeOlder": "10",
        "removeOlderUnit": "60",
        "x": 810,
        "y": 920,
        "id": "ba176ccf.0829d",
        "type": "trigger",
        "op1": "1",
        "op2": "0",
        "op1type": "str",
        "op2type": "str",
        "duration": "3",
        "extend": true,
        "units": "s",
        "reset": "",
        "x": 580,
        "y": 880,
                "1d6090f6.3810bf",
                "c077af9f.b1d4"
        "id": "bb81477c.c915a8",
        "type": "comment",
        "name": "actions on actuators",
        "info": "",
        "x": 610,
        "y": 700,
        "id": "6ee5f848.1a5268",
        "type": "comment",
        "name": "actions on dashboard",
        "info": "",
        "x": 620,
        "y": 820,
        "id": "2bc2e927.e23946",
        "type": "e-mail",
        "server": "smtp.gmail.com",
        "port": "465",
        "name": "infosmick@gmail.com",
        "dname": "mail",
        "x": 790,
        "y": 1000,
        "id": "e42ade52.5ae61",
        "type": "twitter out",
        "twitter": "",
        "name": "tweet",
        "x": 790,
        "y": 1080,
        "id": "2f1b34a3.80b4ac",
        "type": "comment",
        "name": "actions on social",
        "info": "",
        "x": 600,
        "y": 980,
        "id": "747cc7c.0d3cd38",
        "type": "function",
        "name": "alarm msg",
        "func": "function timeDate(tz) {\n    var d = new Date(Date.now()+tz*3600000);\n\n    return  d.getUTCHours() + \":\" +\n            d.getUTCMinutes() + \":\" +\n            d.getUTCSeconds() + \" \" +\n            d.getUTCDate()\t+\"/\" +\n            (d.getUTCMonth()+1) + \"/\" +\n            d.getUTCFullYear();\n}\n\nmsg.payload=\"alarm from Smick at \" +\n            timeDate(1);\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 590,
        "y": 1040,
                "21643b7a.39bdf4"
        "id": "21643b7a.39bdf4",
        "type": "debug",
        "active": true,
        "console": "false",
        "complete": "false",
        "x": 810,
        "y": 1160,
        "id": "45acf18.6e86f1",
        "type": "comment",
        "name": "enable/disable",
        "info": "",
        "x": 600,
        "y": 560,
        "id": "715a9ee0.f0026",
        "label": "button enable",
        "order": 1,
        "width": 0,
        "height": 0,
        "passthru": true,
        "topic": "",
        "style": "",
        "onvalue": "click==d3=0",
        "onicon": "",
        "oncolor": "",
        "offvalue": "click==null",
        "officon": "",
        "offcolor": "",
        "x": 600,
        "y": 620,
                "595fac32.0e1834"
        "id": "1e044ae2.090ee5",
        "type": "switch",
        "name": "parse",
        "rules": [
                "t": "cont",
                "v": "CONN",
                "vt": "str"
                "t": "cont",
                "v": "CLICK",
                "vt": "str"
        "checkall": "false",
        "outputs": 2,
        "x": 290,
        "y": 880,
                "10dd847e.0b60bc"
                "5dd05f78.759f3",
                "ba176ccf.0829d",
                "747cc7c.0d3cd38"
        "id": "dc034ee5.b2f",
        "name": "reset",
        "order": 0,
        "width": "0",
        "height": "0",
        "label": "reset",
        "color": "",
        "icon": "",
        "payload": "RESET",
        "topic": "",
        "x": 370,
        "y": 40,
                "595fac32.0e1834"
        "id": "2fb4e76.9ec5c18",
        "type": "ui_group",
        "z": "",
        "name": "digital output",
        "tab": "b0130d37.f74d9",
        "order": 1,
        "disp": true,
        "width": "6"
        "id": "9b895ead.8e0b9",
        "type": "ui_group",
        "z": "",
        "name": "analogic output",
        "order": 2,
        "disp": true,
        "width": "6"
        "id": "9488c7a0.65a508",
        "type": "ui_group",
        "z": "",
        "name": "Button",
        "tab": "8bcc9ed2.24e07",
        "order": 1,
        "disp": false,
        "width": "6"
        "type": "ui_group",
        "z": "",
        "name": "console",
        "order": 1,
        "disp": true,
        "width": "6"
        "id": "b0130d37.f74d9",
        "type": "ui_tab",
        "z": "",
        "name": "LED",
        "order": 2
        "id": "8bcc9ed2.24e07",
        "type": "ui_tab",
        "z": "",
        "name": "Button",
        "order": 3
        "type": "ui_tab",
        "z": "",
        "name": "Console",
        "order": 1
infosmick
created 5 months, 1 week ago
  • change (x3)
  • comment (x5)
  • debug (x3)
  • e-mail (x1)
  • function (x3)
  • mqtt in (x1)
  • mqtt out (x1)
  • mqtt-broker (x2)
  • switch (x2)
  • trigger (x2)
  • twitter out (x1)
  • subflow (x3)
  • subflow:227e1b69.92def4 (x1)
  • subflow:8c17b331.cd1c7 (x1)
  • subflow:cb252ff.0027dd (x1)
  • ui_button (x3)
  • ui_chart (x1)
  • ui_gauge (x1)
  • ui_group (x7)
  • ui_slider (x1)
  • ui_switch (x2)
  • ui_tab (x6)
  • ui_text (x2)
  • ui_text_input (x1)
