EMC from Temperature and Humidity
Listens to an MQTT broker for temperature and humidity. Then calculates the EMC (equilibrium moisture content) and posts the calculated value to an MQTT broker. Designed for use with an EmonCMS.
Written by Berkeley Fergusson in August 2016.
[{"id":"83cf3f33.85205","type":"mqtt-broker","z":"","broker":"10.1.10.200","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willRetain":null,"willPayload":"","birthTopic":"","birthQos":"0","birthRetain":null,"birthPayload":""},{"id":"68c3c93f.51d4b8","type":"mqtt in","z":"5ab7703b.4b958","name":"Bench Temperature","topic":"emon/EmonTH1/temperature","broker":"83cf3f33.85205","x":141,"y":118,"wires":[["fef4f107.56746"]]},{"id":"7d4ed145.fe8ee","type":"debug","z":"5ab7703b.4b958","name":"","active":false,"console":"false","complete":"true","x":919,"y":261,"wires":[]},{"id":"fef4f107.56746","type":"function","z":"5ab7703b.4b958","name":"str to float","func":"var temp = parseFloat(msg.payload)\nnewMsg = msg\nnewMsg.payload = temp\nreturn newMsg;","outputs":1,"noerr":0,"x":166,"y":176,"wires":[["a19bc9bf.b48de8"]]},{"id":"d8f27098.71576","type":"function","z":"5ab7703b.4b958","name":"All Values in one Msg","func":"context.data = context.data || {};\nif(msg.payload < 0){\n    var hum = msg.payload + 101;\n    context.data.humidity = hum;\n    msg = null;\n} else if (msg.payload >= 0) {\n    var temp = msg.payload - 100;\n    context.data.tempF = temp;\n    msg = null;\n} else msg = null;\n\nif(context.data.humidity != null && context.data.tempF != null){\n    var hum = context.data.humidity;\n    var temp = context.data.tempF;\n    context.data = null;\n    return {humidity: hum, tempF: temp};\n    //return {humidity: context.data.humidity, temp: context.data.tempF};\n} else return msg;","outputs":"1","noerr":0,"x":449,"y":365,"wires":[["f0a17ab5.0a8f58"]]},{"id":"c3cb9f42.f89e1","type":"mqtt in","z":"5ab7703b.4b958","name":"Bench Humidity","topic":"emon/EmonTH1/humidity","broker":"83cf3f33.85205","x":141,"y":429,"wires":[["edb06f6a.47437"]]},{"id":"edb06f6a.47437","type":"function","z":"5ab7703b.4b958","name":"str to float","func":"var temp = parseFloat(msg.payload)\nnewMsg = msg\nnewMsg.payload = temp\nreturn newMsg;","outputs":1,"noerr":0,"x":140,"y":480,"wires":[["6da21578.b689ec"]]},{"id":"6da21578.b689ec","type":"function","z":"5ab7703b.4b958","name":"Make Negative","func":"var hum = msg.payload\nhum -= 101\nmsg.payload = hum\nreturn msg;","outputs":1,"noerr":0,"x":142,"y":545,"wires":[["d8f27098.71576"]]},{"id":"a19bc9bf.b48de8","type":"function","z":"5ab7703b.4b958","name":"C to F","func":"var temp = msg.payload;\ntemp = temp * 1.8 + 32;\nmsg.payload = temp;\n\nreturn msg;","outputs":1,"noerr":0,"x":160,"y":238,"wires":[["3136cdf9.5c67d2"]]},{"id":"3136cdf9.5c67d2","type":"function","z":"5ab7703b.4b958","name":"Make Positive","func":"var temp = msg.payload;\ntemp += 100;\nmsg.payload = temp;\nreturn msg;","outputs":1,"noerr":0,"x":152,"y":304,"wires":[["d8f27098.71576"]]},{"id":"f0a17ab5.0a8f58","type":"function","z":"5ab7703b.4b958","name":"EMC calculation","func":"var tf = msg.tempF\nvar h = msg.humidity\nh /= 100;\nvar t2 = tf * tf;\nvar w = 330 + 0.452 * tf + 0.00415 * t2;\nvar k = 0.791 + 0.000463 * tf - 0.000000844 * t2;\nvar ka = 6.34 + 0.000775 * tf - 0.0000935 * t2;\nvar kb = 1.09 + 0.0284 * tf - 0.0000904 * t2;\nvar m = 1800 / w * ( k * h / (1 - k * h)+ (ka * k * h + 2 * ka * kb * k * k * h * h)/ (1 + ka * k * h + ka * kb * k * k * h * h));\nreturn {\"payload\": m};","outputs":1,"noerr":0,"x":670,"y":366,"wires":[["7d4ed145.fe8ee","5f8222bd.4b86ec"]]},{"id":"5f8222bd.4b86ec","type":"mqtt out","z":"5ab7703b.4b958","name":"","topic":"emon/EmonTH1/EMC2_Bench","qos":"","retain":"","broker":"83cf3f33.85205","x":941,"y":366,"wires":[]}]
Created 11 years, 2 months ago
Updated 11 years ago
  • function (x7)
  • mqtt in (x2)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • EmonCMS
  • EMC
