ArtNET flow with dashboard control
ArtNET flow with dashboard control for each channel.
Test setup :
R DMX Ch 1 - G DMX Ch 2 - B DMX Ch 3 - Spot 1 DMX Ch 4 - Spot 2 DMX Ch 5 - Spot 3 DMX Ch 6 -
Enttec Open DMX Ethernet with IP 10.10.4.5
[{"id":"a2924e7b.f302b","type":"function","z":"c3aed0d3.3ce58","name":"Set Red","func":"var Red= msg.payload;\nmsg.payload = {\n  buckets: [\n    {channel: 1, value: [Red]},\n    ]\n};\nreturn msg;","outputs":1,"noerr":0,"x":700,"y":301,"wires":[["beb72fce.87d0e"]]},{"id":"8b7ea4e8.566388","type":"ui_slider","z":"c3aed0d3.3ce58","name":"  RED","label":"RED","group":"2d57be57.a88422","order":0,"width":0,"height":0,"passthru":true,"topic":"","min":0,"max":"255","step":1,"x":466,"y":301,"wires":[["a2924e7b.f302b"]]},{"id":"beb72fce.87d0e","type":"artnet out","z":"c3aed0d3.3ce58","name":"Open DMX Ethernet","address":"10.10.4.5","port":6454,"size":512,"rate":40,"universe":"0","x":1058,"y":459,"wires":[]},{"id":"1b716f.c1ba0e91","type":"function","z":"c3aed0d3.3ce58","name":"Set Green","func":"var Green= msg.payload;\nmsg.payload = {\n  buckets: [\n    {channel: 2, value: [Green]},\n    ]\n};\nreturn msg;","outputs":1,"noerr":0,"x":707.5,"y":366,"wires":[["beb72fce.87d0e"]]},{"id":"3594d40e.33df8c","type":"ui_slider","z":"c3aed0d3.3ce58","name":"GREEN","label":"GREEN","group":"2d57be57.a88422","order":0,"width":0,"height":0,"passthru":true,"topic":"","min":0,"max":"255","step":1,"x":476.5,"y":365,"wires":[["1b716f.c1ba0e91"]]},{"id":"5e9c2d37.ec0cc4","type":"function","z":"c3aed0d3.3ce58","name":"Set Blue","func":"var Blue= msg.payload;\nmsg.payload = {\n  buckets: [\n    {channel: 3, value: [Blue]},\n    ]\n};\nreturn msg;","outputs":1,"noerr":0,"x":695.5,"y":428,"wires":[["beb72fce.87d0e"]]},{"id":"eb33e682.6922c8","type":"ui_slider","z":"c3aed0d3.3ce58","name":" BLUE","label":"BLUE","group":"2d57be57.a88422","order":0,"width":0,"height":0,"passthru":true,"topic":"","min":0,"max":"255","step":1,"x":463.5,"y":429,"wires":[["5e9c2d37.ec0cc4"]]},{"id":"b30ef2.9ef1911","type":"ui_switch","z":"c3aed0d3.3ce58","name":"On / Off","label":"On / Off","group":"2d57be57.a88422","order":0,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"255","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":223,"y":364,"wires":[["8b7ea4e8.566388","3594d40e.33df8c","eb33e682.6922c8"]]},{"id":"973a88d.306c378","type":"function","z":"c3aed0d3.3ce58","name":"Set Spot 1","func":"var Spot1= msg.payload;\nmsg.payload = {\n  buckets: [\n    {channel: 4, value: [Spot1]},\n    ]\n};\nreturn msg;","outputs":1,"noerr":0,"x":706,"y":497,"wires":[["beb72fce.87d0e"]]},{"id":"4b3176d4.17b1f8","type":"ui_slider","z":"c3aed0d3.3ce58","name":" Spot 1","label":"Spot 1","group":"2d57be57.a88422","order":0,"width":0,"height":0,"passthru":true,"topic":"","min":0,"max":"255","step":1,"x":462,"y":497,"wires":[["973a88d.306c378"]]},{"id":"72e4bd08.a88744","type":"function","z":"c3aed0d3.3ce58","name":"Set Spot 2","func":"var Spot2= msg.payload;\nmsg.payload = {\n  buckets: [\n    {channel: 5, value: [Spot2]},\n    ]\n};\nreturn msg;","outputs":1,"noerr":0,"x":703.5,"y":562,"wires":[["beb72fce.87d0e"]]},{"id":"48a48417.0d1fcc","type":"ui_slider","z":"c3aed0d3.3ce58","name":"Spot 2","label":"Spot 2","group":"2d57be57.a88422","order":0,"width":0,"height":0,"passthru":true,"topic":"","min":0,"max":"255","step":1,"x":462.5,"y":561,"wires":[["72e4bd08.a88744"]]},{"id":"f3233eb4.ffd73","type":"function","z":"c3aed0d3.3ce58","name":"Set Spot 3","func":"var Spot3= msg.payload;\nmsg.payload = {\n  buckets: [\n    {channel: 6, value: [Spot3]},\n    ]\n};\nreturn msg;","outputs":1,"noerr":0,"x":701.5,"y":624,"wires":[["beb72fce.87d0e"]]},{"id":"e510d56b.2f53c8","type":"ui_slider","z":"c3aed0d3.3ce58","name":"Spot 3","label":"Spot 3","group":"2d57be57.a88422","order":0,"width":0,"height":0,"passthru":true,"topic":"","min":0,"max":"255","step":1,"x":459.5,"y":625,"wires":[["f3233eb4.ffd73"]]},{"id":"bb6b6c8b.7a2f","type":"ui_switch","z":"c3aed0d3.3ce58","name":"On / Off","label":"On / Off","group":"2d57be57.a88422","order":0,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"255","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":219,"y":560,"wires":[["4b3176d4.17b1f8","48a48417.0d1fcc","e510d56b.2f53c8"]]},{"id":"2d57be57.a88422","type":"ui_group","z":"","name":"RGB Colour Mix","tab":"58e94b4b.f3b744","disp":true,"width":"6"},{"id":"58e94b4b.f3b744","type":"ui_tab","z":"","name":"ArtNET / DMX","icon":"dashboard"}]
Created 7 years, 8 months ago
  • function (x6)
  • artnet out (x1)
  • ui_group (x1)
  • ui_slider (x6)
  • ui_switch (x2)
  • ArtNET
  • DMX
  • Dashboard
