Temperature/ON-OFF Week Scheduler UI-Template Node-Red Dashboard
This allows users to set up a 24h scheduler for each day of the week in a quick and easy way.
It is a customization of Peter Scargill Thermostat Weekend so all credits goes to him.
In the Comment node you can find instructions on how to create more schedulers in the same UI, just need to copy/paste the flow of a single scheduler and find/replace the name of variables listed in the Comment node.
UI Preview
alt text
alt text
Fixed some bugs with the original scheduler. If you have any comment or suggestions let me know.
Enjoy
[{"id":"9a2a7615.455c48","type":"ui_template","z":"90cc983a.804858","group":"9b8f575a.b741a8","name":"css etc","order":4,"width":"0","height":"0","format":"<style>\n\n.filled { height: 48px !important;padding: 0 !important; margin: 0 !important;}\n.nr-dashboard-template { padding: 0; margin: 0;}\n.rounded { border-radius: 12px 12px 12px 12px;}\n.bigfont { font-size: 18px;}\n.smallfont { font-size: 12px;}\n.thedays { cursor:pointer; vertical-align:bottom; height:48px; }\n.the2px  { background-color: #9E9E9E; height:2px; }\n.theblocks {width:100%; height:0%; background-color:#4CAF50; }\n.greybuttons { background-color:#009688 !important; width:48px; border: none;}\n.thetemps { cursor:pointer; font-size:70%; color:#9E9E9E !important; }\n.smallheadings { color:white; font-size:80%; }\n\n</style>\n\n<script>\nvar current=1;\n\n$('.vibrate').on('click', function() {\n  navigator.vibrate(100);\n});\n\nfunction restore_bg(x) {\n            $(this).css(\"background-color\", x);\n    };\n\n$('.touched').on('mousedown', function() {\n    \n    var x= $(this).css(\"background-color\");\n    $(this).css(\"background-color\", \"yellow\");\n    \n    setTimeout(restore_bg.bind(this,x),50);\n    navigator.vibrate(80);\n    });\n    \n</script>","storeOutMessages":false,"fwdInMessages":true,"x":217,"y":89,"wires":[[]]},{"id":"dfd41566.f73768","type":"ui_template","z":"90cc983a.804858","group":"9b8f575a.b741a8","name":"Settings page","order":3,"width":"6","height":"6","format":"<script>\nvar thedays=[\"DOMENICA\",\"LUNEDI\",\"MARTEDI\",\"MERCOLEDI\",\"GIOVEDI\",\"VENERDI\",\"SABATO\"];\nvar ID = \"AA\";\n\nvar last=29;\n\nfunction bar(mm,val)\n{\nif (val==14) { $(mm).height(\"12%\"); $(mm).css('background-color', '#1E88E5'); } //blue\nif (val==15) { $(mm).height(\"16%\"); $(mm).css('background-color', '#039BE5'); }\nif (val==16) { $(mm).height(\"20%\"); $(mm).css('background-color', '#00ACC1'); } \nif (val==17) { $(mm).height(\"24%\"); $(mm).css('background-color', '#039BE5'); } // cyan\nif (val==18) { $(mm).height(\"28%\"); $(mm).css('background-color', '#00ACC1'); }\nif (val==19) { $(mm).height(\"32%\"); $(mm).css('background-color', '#00897B'); } \nif (val==20) { $(mm).height(\"36%\"); $(mm).css('background-color', '#388E3C'); } // green\nif (val==21) { $(mm).height(\"40%\"); $(mm).css('background-color', '#689F38'); }\nif (val==22) { $(mm).height(\"44%\"); $(mm).css('background-color', '#C0CA33'); }\nif (val==23) { $(mm).height(\"48%\"); $(mm).css('background-color', '#FDD835'); } // yellow\nif (val==24) { $(mm).height(\"52%\"); $(mm).css('background-color', '#FBC02D'); }\nif (val==25) { $(mm).height(\"56%\"); $(mm).css('background-color', '#FFA000'); }\nif (val==26) { $(mm).height(\"60%\"); $(mm).css('background-color','#E64A19'); } // red\n    \n}\n\nfunction stat(text)\n{\n$(\"#info\"+ID).text(text);\nvar tm=setTimeout(function(){ $(\"#info\"+ID).text(\"Ok\"); clearTimeout(tm);}, 3000);\n}\n\nfunction selec(val,sta)\n{\nvar w=\"#td\"+val+ID;\n if (sta) $(w).css('background-color','#4CAF50'); else $(w).css('background-color','#FFC107');\n}\n\n    (function(scope){\n        scope.ID = ID;\n        scope.send({payload: '29'})\n        scope.$watch('msg', function(msg) {\n            selec(last,0); last=msg.selector; selec(last,1);\n            for (var x=0; x<24; x++) \n                { \n                    var w=\"#t\"+x+ID; bar(w,msg.timing[((msg.days-1)*24)+x]); \n                    var v=\"#v\"+x+ID; $(v).text(msg.timing[((msg.days-1)*24)+x]+\"°\")\n                } \n            for (var x=0; x<2; x++) { var w=\"#s\"+x+ID; $(w).text(msg.timing[168+x]); }\n             $(\"#d0\"+ID).text(thedays[msg.days-1]);\n             if ((last>4) &&(last<29))\n                 $(\"#current\"+ID).text(msg.timing[((msg.days-1)*24)+last-5] + \"°\");\n             else\n                 $(\"#current\"+ID).text(\"-\");\n                 \n            if (msg.foryou!=\"\") { stat(msg.foryou);  }\n            \n             \n        });\n \n    })(scope);\n      \n\n</script>\n<table width=\"100%\">\n    \n    <tr>\n        <td colspan=24><center><span class=\"smallheadings\" >Giorno</span></center></td>\n        <!--<td colspan=3><center><span class=\"smallheadings\">Clima</span></center></td>\n        <td colspan=3><center><span class=\"smallheadings\">Fuori casa</span></center></td>-->\n    </tr>\n   \n    <tr>\n        <td ng-click=\"send({payload: '29'})\" colspan=24><center><span id=\"{{ 'd0' + ID }}\" style=\"cursor:pointer;color:white;font-size:120%\">LUNEDI</span></center></td>\n        <!--<td ng-click=\"send({payload: '1'})\" colspan=3><center><span id=\"s0\" style=\"color:white;font-size:120%\">14</span></center></td>\n        <td ng-click=\"send({payload: '2'})\" colspan=3><center><span id=\"s1\" style=\"color:white;font-size:120%\">20</span></center></td>-->\n    </tr>\n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td29' + ID }}\" colspan=24 style=\"background-color:#9E9E9E;height:2px;\"></td>        \n       <!-- <td id=\"td1\" colspan=3 style=\"background-color:#9E9E9E;height:2px;\"></td>\n        <td id=\"td2\" colspan=3 style=\"background-color:#9E9E9E;height:2px;\"></td>-->\n    </tr>  \n\n    <tr>\n        <td ng-click=\"send({payload: '5'})\" class=\"thedays\"><span id=\"{{ 'v0' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't0' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '6'})\" class=\"thedays\"><span id=\"{{ 'v1' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't1' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '7'})\" class=\"thedays\"><span id=\"{{ 'v2' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't2' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '8'})\" class=\"thedays\"><span id=\"{{ 'v3' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't3' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '9'})\" class=\"thedays\"><span id=\"{{ 'v4' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't4' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '10'})\" class=\"thedays\"><span id=\"{{ 'v5' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't5' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '11'})\" class=\"thedays\"><span id=\"{{ 'v6' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't6' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '12'})\" class=\"thedays\"><span id=\"{{ 'v7' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't7' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '13'})\" class=\"thedays\"><span id=\"{{ 'v8' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't8' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '14'})\" class=\"thedays\"><span id=\"{{ 'v9' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't9' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '15'})\" class=\"thedays\"><span id=\"{{ 'v10' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't10' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '16'})\" class=\"thedays\"><span id=\"{{ 'v11' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't11' + ID }}\" class=\"theblocks\"></div></td>\n    </tr>  \n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td5' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td6' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td7' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td8' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td9' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td10' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td11' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td12' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td13' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td14' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td15' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td16' + ID }}\" class=\"the2px\"></td>\n    </tr>   \n    \n    <tr>\n        <td align=\"center\">0</td>\n        <td align=\"center\">1</td>\n        <td align=\"center\">2</td>\n        <td align=\"center\">3</td>\n        <td align=\"center\">4</td>\n        <td align=\"center\">5</td>\n        <td align=\"center\">6</td>\n        <td align=\"center\">7</td>\n        <td align=\"center\">8</td>\n        <td align=\"center\">9</td>\n        <td align=\"center\">10</td>\n        <td align=\"center\">11</td>\n    </tr> \n    \n    <tr>\n        <td ng-click=\"send({payload: '17'})\" class=\"thedays\"><span id=\"{{ 'v12' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't12' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '18'})\" class=\"thedays\"><span id=\"{{ 'v13' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't13' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '19'})\" class=\"thedays\"><span id=\"{{ 'v14' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't14' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '20'})\" class=\"thedays\"><span id=\"{{ 'v15' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't15' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '21'})\" class=\"thedays\"><span id=\"{{ 'v16' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't16' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '22'})\" class=\"thedays\"><span id=\"{{ 'v17' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't17' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '23'})\" class=\"thedays\"><span id=\"{{ 'v18' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't18' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '24'})\" class=\"thedays\"><span id=\"{{ 'v19' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't19' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '25'})\" class=\"thedays\"><span id=\"{{ 'v20' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't20' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '26'})\" class=\"thedays\"><span id=\"{{ 'v21' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't21' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '27'})\" class=\"thedays\"><span id=\"{{ 'v22' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't22' + ID }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '28'})\" class=\"thedays\"><span id=\"{{ 'v23' + ID }}\" class=\"thetemps\"></span><div id=\"{{ 't23' + ID }}\" class=\"theblocks\"></div></td>\n    </tr>  \n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td17' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td18' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td19' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td20' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td21' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td22' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td23' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td24' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td25' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td26' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td27' + ID }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td28' + ID }}\" class=\"the2px\"></td>\n    </tr>  \n    \n    <tr>\n        <td align=\"center\">12</td>\n        <td align=\"center\">13</td>\n        <td align=\"center\">14</td>\n        <td align=\"center\">15</td>\n        <td align=\"center\">16</td>\n        <td align=\"center\">17</td>\n        <td align=\"center\">18</td>\n        <td align=\"center\">19</td>\n        <td align=\"center\">20</td>\n        <td align=\"center\">21</td>\n        <td align=\"center\">22</td>\n        <td align=\"center\">23</td>\n    </tr> \n    \n    <tr height=\"20px\">\n        <td colspan=2 class=\"smallheadings\">Azioni:</td>\n\n        <td colspan=10 ><center><span id=\"{{ 'info' + ID }}\" class=\"smallheadings\" ></span></center></td>\n\n    </tr>\n    \n    <tr height=\"10px\">\n        <td colspan=\"12\"></td>\n    </tr>\n\n    <tr style=\"height:48px\">\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'd'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"keyboard_arrow_down\">\n                    <md-tooltip md-direction=\"bottom\">DECREMENTA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n        \n        <td colspan=2><center><span id=\"{{ 'current' + ID }}\" style=\"color:white;font-size:120%\">-</span></center></td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'u'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"keyboard_arrow_up\">\n                    <md-tooltip md-direction=\"bottom\">INCREMENTA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'r'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"content_copy\">\n                    <md-tooltip md-direction=\"bottom\">COPIA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 's'})\"> \n                 <ng-md-icon style=\"color: #fff;\" icon=\"save\">\n                    <md-tooltip md-direction=\"bottom\">SALVA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\"  ng-click=\"send({payload: 'c'})\"> \n                 <ng-md-icon style=\"color: #fff;\" icon=\"cancel\">\n                    <md-tooltip md-direction=\"bottom\">ANNULLA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n        <td colspan=1></td>\n    </tr>\n\n</table>","storeOutMessages":false,"fwdInMessages":false,"x":237,"y":126,"wires":[["97430b63.1f4c88"]]},{"id":"97430b63.1f4c88","type":"function","z":"90cc983a.804858","name":"Process controls","func":"if ( typeof context.days == 'undefined' ) context.days=1;\nif ( typeof context.selector == 'undefined' ) context.selector=29;\nif ( typeof context.saving == 'undefined' ) context.saving=1;\nif ( typeof context.global.timing == 'undefined' ) \n    {\n        context.global.timing=[\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        6,14\n                        ];\n        context.saving=1;                    \n    }\nvar timing=global.get(\"timing\");\n\nswitch (msg.payload)\n    {\n    case \"u\" :  if ((context.selector>4)&&(context.selector<29))\n                {\n                    timing[((context.days-1)*24)+context.selector-5]++; \n                    if (timing[((context.days-1)*24)+context.selector-5]>26){ timing[((context.days-1)*24)+context.selector-5]=26; msg.foryou=\"Limite raggiunto\";}\n                    else msg.foryou=\"Temperatura aumentata\";\n                }\n                if (context.selector==1) { if (timing[168+(context.selector-1)]<26) {  timing[168+(context.selector-1)]++; msg.foryou=\"Temperatura clima aumentata di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector==2) { if (timing[168+(context.selector-1)]<26) {  timing[168+(context.selector-1)]++; msg.foryou=\"Temperatura fuori casa aumentata di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector==29) { msg.foryou=\"Giorno successivo\"; context.days++; if (context.days>7) { context.days = 1; } }\n                break;\n    case \"d\" :  if ((context.selector>4)&&(context.selector<29))\n                {\n                    timing[((context.days-1)*24)+context.selector-5]--; \n                    if (timing[((context.days-1)*24)+context.selector-5]<14){ timing[((context.days-1)*24)+context.selector-5]=14; msg.foryou=\"Limite raggiunto\";}\n                    else msg.foryou=\"Temperatura decrementata\";\n                }\n                if (context.selector==1) { if (timing[168+(context.selector-1)]>12) { timing[168+(context.selector-1)]--; msg.foryou=\"Temperatura clima diminuita di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector==2) { if (timing[168+(context.selector-1)]>12) { timing[168+(context.selector-1)]--; msg.foryou=\"Temperatura fuori casa diminuita di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector==29) {  msg.foryou=\"Giorno precedente\";  context.days--; if (context.days < 1) { context.days = 7;  } }\n                break;\n    case 'r' :  if ((context.selector>=5)&&(context.selector<28))\n                        {\n                         timing[((context.days-1)*24)+context.selector-4]=timing[((context.days-1)*24)+context.selector-5];   \n                         context.selector++;\n                         msg.foryou=\"Temperatura copiata nello slot successivo\";\n                        }\n                if ((context.selector==29)&&(context.days<7))\n                        {\n                         for (var a=0;a<24;a++)\n                            {\n                             timing[((context.days)*24)+a]=timing[((context.days-1)*24)+a];   \n                            }\n                         context.days++;\n                         msg.foryou=\"Impostazioni copiate nel giorno successivo\";\n                        }\n                        else if(context.days==7)\n                            msg.foryou=\"Fine della settimana raggiunto!\";\n                break;\n    case 's': context.saving=0;  msg.foryou=\"Impostazioni salvate\"; break;\n    case '1':\n    case '2':\n    case '3':\n    case '4':\n    case '5':\n    case '6':\n    case '7':\n    case '8':\n    case '9':\n    case '10':\n    case '11':\n    case '12':\n    case '13':\n    case '14':\n    case '15':\n    case '16':\n    case '17':\n    case '18':\n    case '19':\n    case '20':\n    case '21':\n    case '22':\n    case '23':\n    case '24':\n    case '25':\n    case '26':\n    case '27':\n    case '28':\n    case '29': context.selector=parseInt(msg.payload);\n               if (msg.payload=='1') msg.foryou=\"Temperatura clima selezionata\"; \n               else if (msg.payload=='2') msg.foryou=\"Temperatura fuori casa selezionata\";\n               else if (msg.payload=='29') msg.foryou=\"Giorno selezionato\";\n               else  msg.foryou=\"Regolazione temperatura ore: \" + (parseInt(msg.payload)-5);\n    break;\n    case 'c' : msg.payload=\"niente\";  msg.foryou=\"Cambiamenti annullati\"; node.send([null,null,msg]);\n    }\n\nmsg.temperatures=context.temperatures;\nmsg.timing=timing;\nmsg.days=context.days;\nmsg.selector=context.selector;\n\nnode.send([msg,null,null]);\n\nif (context.saving===0) \n    { \n       msg.topic=\"\";\n        msg.timing=\"\";\n        msg.payload=JSON.stringify(timing);\n        node.send([null,msg,null]); \n        context.saving=1;\n    }\n    msg.foryou=\"\"","outputs":"3","noerr":0,"x":460,"y":178,"wires":[["387461ec.dc158e"],["ac33e6d0.c163e8"],["8f477cbb.0b78c"]]},{"id":"aeaa17cd.6a07f8","type":"inject","z":"90cc983a.804858","name":"Once only","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":true,"x":245,"y":226,"wires":[["97430b63.1f4c88","94321f9f.323dc"]]},{"id":"bdc4da3.12a8028","type":"inject","z":"90cc983a.804858","name":"Every minute","topic":"","payload":"","payloadType":"str","repeat":"60","crontab":"","once":true,"x":218,"y":347,"wires":[["aaff02d9.db667"]]},{"id":"94288cf.ccce97","type":"function","z":"90cc983a.804858","name":"Process heat","func":"var timing=global.get(\"timing\");\nvar now = new Date(msg.time);\nmsg.payload=timing[(now.getDay()*24)+now.getHours()];\nmsg.frost=timing[168];\nmsg.away=timing[169];\nnode.status({fill:\"blue\",shape:\"dot\",text:\"Set point \" + msg.payload + \"°C\"});\nreturn msg;\n\n","outputs":1,"noerr":0,"x":544,"y":347,"wires":[["715747d.b57acb8"]]},{"id":"ac33e6d0.c163e8","type":"file","z":"90cc983a.804858","name":"backup","filename":"/home/pi/data/thermo_scheduler.log","appendNewline":true,"createDir":true,"overwriteFile":"true","x":649,"y":177,"wires":[]},{"id":"94321f9f.323dc","type":"file in","z":"90cc983a.804858","name":"Restore","filename":"/home/pi/data/thermo_scheduler.log","format":"utf8","x":438,"y":256,"wires":[["d9f39fdb.ade5c"]]},{"id":"d9f39fdb.ade5c","type":"function","z":"90cc983a.804858","name":"Restore data from SD","func":"context.global.timing=JSON.parse(msg.payload);\nmsg.payload=\"\";\nreturn msg;","outputs":1,"noerr":0,"x":638,"y":256,"wires":[["720ced17.741ec4"]]},{"id":"715747d.b57acb8","type":"debug","z":"90cc983a.804858","name":"","active":true,"console":"false","complete":"true","x":715.5,"y":347,"wires":[]},{"id":"db363d9e.83b29","type":"inject","z":"90cc983a.804858","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":true,"x":242,"y":1826,"wires":[["8ab4f286.9e135"]]},{"id":"8ab4f286.9e135","type":"moment","z":"90cc983a.804858","name":"","topic":"","input":"payload","inputType":"msg","inTz":"UTC","adjAmount":"2","adjType":"hours","adjDir":"add","format":"lll","locale":"it_IT","output":"payload","outputType":"msg","outTz":"UTC","x":445,"y":1826,"wires":[["1b39179f.d8dd28"]]},{"id":"1b39179f.d8dd28","type":"ui_text","z":"90cc983a.804858","group":"f0089344.b8ed1","order":0,"width":0,"height":0,"name":"","label":"","format":"{{msg.payload}}","layout":"col-center","x":636,"y":1826,"wires":[]},{"id":"b9bfb4a3.0cea48","type":"link in","z":"90cc983a.804858","name":"restore","links":["8f477cbb.0b78c"],"x":298.5,"y":277,"wires":[["94321f9f.323dc"]]},{"id":"8f477cbb.0b78c","type":"link out","z":"90cc983a.804858","name":"restore","links":["b9bfb4a3.0cea48"],"x":611.5,"y":214,"wires":[]},{"id":"acc52a0d.3759b8","type":"link in","z":"90cc983a.804858","name":"restoreSD","links":["720ced17.741ec4"],"x":298,"y":178,"wires":[["97430b63.1f4c88"]]},{"id":"720ced17.741ec4","type":"link out","z":"90cc983a.804858","name":"restoreSD","links":["acc52a0d.3759b8"],"x":792,"y":256,"wires":[]},{"id":"387461ec.dc158e","type":"link out","z":"90cc983a.804858","name":"setSettings","links":["89be7c05.e44d8"],"x":612.5,"y":138,"wires":[]},{"id":"89be7c05.e44d8","type":"link in","z":"90cc983a.804858","name":"setSettings","links":["387461ec.dc158e"],"x":104.5,"y":126,"wires":[["dfd41566.f73768"]]},{"id":"aaff02d9.db667","type":"moment","z":"90cc983a.804858","name":"time","topic":"","input":"","inputType":"date","inTz":"UTC","adjAmount":"2","adjType":"hours","adjDir":"add","format":"","locale":"it_IT","output":"time","outputType":"msg","outTz":"UTC","x":383.5,"y":347,"wires":[["94288cf.ccce97"]]},{"id":"40c5d4d9.8147ac","type":"ui_template","z":"90cc983a.804858","group":"f1a9197e.2dfc88","name":"Settings page","order":3,"width":"6","height":"6","format":"<script>\n\nvar thedays1=[\"DOMENICA\",\"LUNEDI\",\"MARTEDI\",\"MERCOLEDI\",\"GIOVEDI\",\"VENERDI\",\"SABATO\"];\n\nvar ID1 = \"BB\";\n\nvar last1=29;\n\nfunction stat1(text)\n{\n$(\"#info\"+ID1).text(text);\nvar tm=setTimeout(function(){ $(\"#info\"+ID1).text(\"Ok\"); clearTimeout(tm);}, 3000);\n}\n\nfunction selec1(val,sta)\n{\nvar w=\"#td\"+val+ID1;\n if (sta) $(w).css('background-color','#4CAF50'); else $(w).css('background-color','#FFC107');\n}\n\n\n    (function(scope){\n        scope.ID1 = ID1;\n        scope.send({payload: '29'})\n        scope.$watch('msg', function(msg) {\n            selec1(last1,0); last1=msg.selector; selec1(last1,1);\n            for (var x=0; x<24; x++) \n                { \n                    var w=\"#t\"+x+ID1; bar(w,msg.timing[((msg.days-1)*24)+x]); \n                    var v=\"#v\"+x+ID1; $(v).text(msg.timing[((msg.days-1)*24)+x]+\"°\")\n                } \n            for (var x=0; x<2; x++) { var w=\"#s\"+x+ID1; $(w).text(msg.timing[168+x]); }\n             $(\"#d0\"+ID1).text(thedays1[msg.days-1]);\n             if ((last1>4) &&(last1<29))\n                 $(\"#current\"+ID1).text(msg.timing[((msg.days-1)*24)+last1-5] + \"°\");\n             else\n                 $(\"#current\"+ID1).text(\"-\");\n                 \n            if (msg.foryou!=\"\") { stat1(msg.foryou);  }\n            \n             \n        });\n \n    })(scope);\n      \n\n</script>\n<table width=\"100%\">\n    \n    <tr>\n        <td colspan=24><center><span class=\"smallheadings\" >Giorno</span></center></td>\n        <!--<td colspan=3><center><span class=\"smallheadings\">Clima</span></center></td>\n        <td colspan=3><center><span class=\"smallheadings\">Fuori casa</span></center></td>-->\n    </tr>\n   \n    <tr>\n        <td ng-click=\"send({payload: '29'})\" colspan=24><center><span id=\"{{ 'd0' + ID1 }}\" style=\"cursor:pointer;color:white;font-size:120%\">LUNEDI</span></center></td>\n        <!--<td ng-click=\"send({payload: '1'})\" colspan=3><center><span id=\"s0\" style=\"color:white;font-size:120%\">14</span></center></td>\n        <td ng-click=\"send({payload: '2'})\" colspan=3><center><span id=\"s1\" style=\"color:white;font-size:120%\">20</span></center></td>-->\n    </tr>\n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td29' + ID1 }}\" colspan=24 style=\"background-color:#9E9E9E;height:2px;\"></td>        \n       <!-- <td id=\"td1\" colspan=3 style=\"background-color:#9E9E9E;height:2px;\"></td>\n        <td id=\"td2\" colspan=3 style=\"background-color:#9E9E9E;height:2px;\"></td>-->\n    </tr>  \n\n    <tr>\n        <td ng-click=\"send({payload: '5'})\" class=\"thedays\"><span id=\"{{ 'v0' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't0' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '6'})\" class=\"thedays\"><span id=\"{{ 'v1' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't1' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '7'})\" class=\"thedays\"><span id=\"{{ 'v2' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't2' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '8'})\" class=\"thedays\"><span id=\"{{ 'v3' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't3' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '9'})\" class=\"thedays\"><span id=\"{{ 'v4' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't4' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '10'})\" class=\"thedays\"><span id=\"{{ 'v5' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't5' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '11'})\" class=\"thedays\"><span id=\"{{ 'v6' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't6' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '12'})\" class=\"thedays\"><span id=\"{{ 'v7' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't7' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '13'})\" class=\"thedays\"><span id=\"{{ 'v8' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't8' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '14'})\" class=\"thedays\"><span id=\"{{ 'v9' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't9' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '15'})\" class=\"thedays\"><span id=\"{{ 'v10' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't10' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '16'})\" class=\"thedays\"><span id=\"{{ 'v11' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't11' + ID1 }}\" class=\"theblocks\"></div></td>\n    </tr>  \n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td5' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td6' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td7' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td8' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td9' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td10' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td11' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td12' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td13' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td14' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td15' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td16' + ID1 }}\" class=\"the2px\"></td>\n    </tr>   \n    \n    <tr>\n        <td align=\"center\">0</td>\n        <td align=\"center\">1</td>\n        <td align=\"center\">2</td>\n        <td align=\"center\">3</td>\n        <td align=\"center\">4</td>\n        <td align=\"center\">5</td>\n        <td align=\"center\">6</td>\n        <td align=\"center\">7</td>\n        <td align=\"center\">8</td>\n        <td align=\"center\">9</td>\n        <td align=\"center\">10</td>\n        <td align=\"center\">11</td>\n    </tr> \n    \n    <tr>\n        <td ng-click=\"send({payload: '17'})\" class=\"thedays\"><span id=\"{{ 'v12' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't12' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '18'})\" class=\"thedays\"><span id=\"{{ 'v13' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't13' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '19'})\" class=\"thedays\"><span id=\"{{ 'v14' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't14' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '20'})\" class=\"thedays\"><span id=\"{{ 'v15' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't15' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '21'})\" class=\"thedays\"><span id=\"{{ 'v16' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't16' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '22'})\" class=\"thedays\"><span id=\"{{ 'v17' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't17' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '23'})\" class=\"thedays\"><span id=\"{{ 'v18' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't18' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '24'})\" class=\"thedays\"><span id=\"{{ 'v19' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't19' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '25'})\" class=\"thedays\"><span id=\"{{ 'v20' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't20' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '26'})\" class=\"thedays\"><span id=\"{{ 'v21' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't21' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '27'})\" class=\"thedays\"><span id=\"{{ 'v22' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't22' + ID1 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '28'})\" class=\"thedays\"><span id=\"{{ 'v23' + ID1 }}\" class=\"thetemps\"></span><div id=\"{{ 't23' + ID1 }}\" class=\"theblocks\"></div></td>\n    </tr>  \n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td17' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td18' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td19' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td20' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td21' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td22' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td23' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td24' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td25' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td26' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td27' + ID1 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td28' + ID1 }}\" class=\"the2px\"></td>\n    </tr>  \n    \n    <tr>\n        <td align=\"center\">12</td>\n        <td align=\"center\">13</td>\n        <td align=\"center\">14</td>\n        <td align=\"center\">15</td>\n        <td align=\"center\">16</td>\n        <td align=\"center\">17</td>\n        <td align=\"center\">18</td>\n        <td align=\"center\">19</td>\n        <td align=\"center\">20</td>\n        <td align=\"center\">21</td>\n        <td align=\"center\">22</td>\n        <td align=\"center\">23</td>\n    </tr> \n    \n    <tr height=\"20px\">\n        <td colspan=2 class=\"smallheadings\">Azioni:</td>\n\n        <td colspan=10 ><center><span id=\"{{ 'info' + ID1 }}\" class=\"smallheadings\" ></span></center></td>\n\n    </tr>\n    \n    <tr height=\"10px\">\n        <td colspan=\"12\"></td>\n    </tr>\n\n    <tr style=\"height:48px\">\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'd'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"keyboard_arrow_down\">\n                    <md-tooltip md-direction=\"bottom\">DECREMENTA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n        \n        <td colspan=2><center><span id=\"{{ 'current' + ID1 }}\" style=\"color:white;font-size:120%\">-</span></center></td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'u'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"keyboard_arrow_up\">\n                    <md-tooltip md-direction=\"bottom\">INCREMENTA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'r'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"content_copy\">\n                    <md-tooltip md-direction=\"bottom\">COPIA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 's'})\"> \n                 <ng-md-icon style=\"color: #fff;\" icon=\"save\">\n                    <md-tooltip md-direction=\"bottom\">SALVA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\"  ng-click=\"send({payload: 'c'})\"> \n                 <ng-md-icon style=\"color: #fff;\" icon=\"cancel\">\n                    <md-tooltip md-direction=\"bottom\">ANNULLA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n        <td colspan=1></td>\n    </tr>\n\n</table>","storeOutMessages":false,"fwdInMessages":false,"x":327,"y":487,"wires":[["6c91d28d.6473fc"]]},{"id":"6c91d28d.6473fc","type":"function","z":"90cc983a.804858","name":"Process controls","func":"if ( typeof context.days1 == 'undefined' ) context.days1=1;\nif ( typeof context.selector1 == 'undefined' ) context.selector1=29;\nif ( typeof context.saving1 == 'undefined' ) context.saving1=1;\nif ( typeof context.global.timing1 == 'undefined' ) \n    {\n        context.global.timing1=[\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        6,14\n                        ];\n        context.saving1=1;                    \n    }\nvar timing1=global.get(\"timing1\");\n\nswitch (msg.payload)\n    {\n    case \"u\" :  if ((context.selector1>4)&&(context.selector1<29))\n                {\n                    timing1[((context.days1-1)*24)+context.selector1-5]++; \n                    if (timing1[((context.days1-1)*24)+context.selector1-5]>26){ timing1[((context.days1-1)*24)+context.selector1-5]=26; msg.foryou=\"Limite raggiunto\";}\n                    else msg.foryou=\"Temperatura aumentata\";\n                }\n                if (context.selector1==1) { if (timing1[168+(context.selector1-1)]<26) {  timing1[168+(context.selector1-1)]++; msg.foryou=\"Temperatura clima aumentata di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector1==2) { if (timing1[168+(context.selector1-1)]<26) {  timing1[168+(context.selector1-1)]++; msg.foryou=\"Temperatura fuori casa aumentata di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector1==29) { msg.foryou=\"Giorno successivo\"; context.days1++; if (context.days1>7) { context.days1 = 1; } }\n                break;\n    case \"d\" :  if ((context.selector1>4)&&(context.selector1<29))\n                {\n                    timing1[((context.days1-1)*24)+context.selector1-5]--; \n                    if (timing1[((context.days1-1)*24)+context.selector1-5]<14){ timing1[((context.days1-1)*24)+context.selector1-5]=14; msg.foryou=\"Limite raggiunto\";}\n                    else msg.foryou=\"Temperatura decrementata\";\n                }\n                if (context.selector1==1) { if (timing1[168+(context.selector1-1)]>12) { timing1[168+(context.selector1-1)]--; msg.foryou=\"Temperatura clima diminuita di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector1==2) { if (timing1[168+(context.selector1-1)]>12) { timing1[168+(context.selector1-1)]--; msg.foryou=\"Temperatura fuori casa diminuita di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector1==29) {  msg.foryou=\"Giorno precedente\";  context.days1--; if (context.days1 < 1) { context.days1 = 7;  } }\n                break;\n    case 'r' :  if ((context.selector1>=5)&&(context.selector1<28))\n                        {\n                         timing1[((context.days1-1)*24)+context.selector1-4]=timing1[((context.days1-1)*24)+context.selector1-5];   \n                         context.selector1++;\n                         msg.foryou=\"Temperatura copiata nello slot successivo\";\n                        }\n                if ((context.selector1==29)&&(context.days1<7))\n                        {\n                         for (var a=0;a<24;a++)\n                            {\n                             timing1[((context.days1)*24)+a]=timing1[((context.days1-1)*24)+a];   \n                            }\n                         context.days1++;\n                         msg.foryou=\"Impostazioni copiate nel giorno successivo\";\n                        }\n                        else if(context.days1==7)\n                            msg.foryou=\"Fine della settimana raggiunto!\";\n                break;\n    case 's': context.saving1=0;  msg.foryou=\"Impostazioni salvate\"; break;\n    case '1':\n    case '2':\n    case '3':\n    case '4':\n    case '5':\n    case '6':\n    case '7':\n    case '8':\n    case '9':\n    case '10':\n    case '11':\n    case '12':\n    case '13':\n    case '14':\n    case '15':\n    case '16':\n    case '17':\n    case '18':\n    case '19':\n    case '20':\n    case '21':\n    case '22':\n    case '23':\n    case '24':\n    case '25':\n    case '26':\n    case '27':\n    case '28':\n    case '29': context.selector1=parseInt(msg.payload);\n               if (msg.payload=='1') msg.foryou=\"Temperatura clima selezionata\"; \n               else if (msg.payload=='2') msg.foryou=\"Temperatura fuori casa selezionata\";\n               else if (msg.payload=='29') msg.foryou=\"Giorno selezionato\";\n               else  msg.foryou=\"Regolazione temperatura ore: \" + (parseInt(msg.payload)-5);\n    break;\n    case 'c' : msg.payload=\"niente\";  msg.foryou=\"Cambiamenti annullati\"; node.send([null,null,msg]);\n    }\n\nmsg.temperatures=context.temperatures1;\nmsg.timing=timing1;\nmsg.days=context.days1;\nmsg.selector=context.selector1;\n\nnode.send([msg,null,null]);\n\nif (context.saving1===0) \n    { \n       msg.topic=\"\";\n        msg.timing=\"\";\n        msg.payload=JSON.stringify(timing1);\n        node.send([null,msg,null]); \n        context.saving1=1;\n    }\n    msg.foryou=\"\"","outputs":"3","noerr":0,"x":550,"y":539,"wires":[["16c0ac56.9a2ed4"],["c97434d.a8464c8"],["5302156.ac6a2ec"]]},{"id":"1508de6a.35bb12","type":"inject","z":"90cc983a.804858","name":"Once only","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":true,"x":335,"y":587,"wires":[["6c91d28d.6473fc","fc5e38b7.19d788"]]},{"id":"9ef84222.f606","type":"inject","z":"90cc983a.804858","name":"Every minute","topic":"","payload":"","payloadType":"str","repeat":"60","crontab":"","once":true,"x":308,"y":708,"wires":[["4bec742d.96ebdc"]]},{"id":"cc0da780.529c58","type":"function","z":"90cc983a.804858","name":"Process heat","func":"var timing=global.get(\"timing1\");\nvar now = new Date(msg.time);\nmsg.payload=timing[(now.getDay()*24)+now.getHours()];\nmsg.frost=timing[168];\nmsg.away=timing[169];\nnode.status({fill:\"blue\",shape:\"dot\",text:\"Set point \" + msg.payload + \"°C\"});\nreturn msg;\n\n","outputs":1,"noerr":0,"x":636,"y":707,"wires":[["6664655c.f1d2ac"]]},{"id":"c97434d.a8464c8","type":"file","z":"90cc983a.804858","name":"backup","filename":"/home/pi/data/thermo_scheduler_01.log","appendNewline":true,"createDir":true,"overwriteFile":"true","x":739,"y":538,"wires":[]},{"id":"fc5e38b7.19d788","type":"file in","z":"90cc983a.804858","name":"Restore","filename":"/home/pi/data/thermo_scheduler_01.log","format":"utf8","x":528,"y":617,"wires":[["e718c2e.140e14"]]},{"id":"e718c2e.140e14","type":"function","z":"90cc983a.804858","name":"Restore data from SD","func":"context.global.timing1=JSON.parse(msg.payload);\nmsg.payload=\"\";\nreturn msg;","outputs":1,"noerr":0,"x":728,"y":617,"wires":[["e0eb3d1a.8cc7"]]},{"id":"6664655c.f1d2ac","type":"debug","z":"90cc983a.804858","name":"","active":true,"console":"false","complete":"true","x":804.5,"y":708,"wires":[]},{"id":"ef623152.281ea","type":"link in","z":"90cc983a.804858","name":"restore","links":["5302156.ac6a2ec"],"x":388.5,"y":638,"wires":[["fc5e38b7.19d788"]]},{"id":"5302156.ac6a2ec","type":"link out","z":"90cc983a.804858","name":"restore","links":["ef623152.281ea"],"x":701.5,"y":575,"wires":[]},{"id":"9b26a901.c7ff98","type":"link in","z":"90cc983a.804858","name":"restoreSD","links":["e0eb3d1a.8cc7"],"x":388,"y":539,"wires":[["6c91d28d.6473fc"]]},{"id":"e0eb3d1a.8cc7","type":"link out","z":"90cc983a.804858","name":"restoreSD","links":["9b26a901.c7ff98"],"x":882,"y":617,"wires":[]},{"id":"16c0ac56.9a2ed4","type":"link out","z":"90cc983a.804858","name":"setSettings","links":["7feeac82.1b8a14"],"x":702.5,"y":499,"wires":[]},{"id":"7feeac82.1b8a14","type":"link in","z":"90cc983a.804858","name":"setSettings","links":["16c0ac56.9a2ed4"],"x":194.5,"y":487,"wires":[["40c5d4d9.8147ac"]]},{"id":"4bec742d.96ebdc","type":"moment","z":"90cc983a.804858","name":"time","topic":"","input":"","inputType":"date","inTz":"UTC","adjAmount":"2","adjType":"hours","adjDir":"add","format":"","locale":"it_IT","output":"time","outputType":"msg","outTz":"UTC","x":473.5,"y":708,"wires":[["cc0da780.529c58"]]},{"id":"704b3b45.1f3124","type":"ui_template","z":"90cc983a.804858","group":"f59caa4c.0eb048","name":"Settings page","order":3,"width":"6","height":"6","format":"<script>\n\nvar thedays_0=[\"DOMENICA\",\"LUNEDI\",\"MARTEDI\",\"MERCOLEDI\",\"GIOVEDI\",\"VENERDI\",\"SABATO\"];\n\nvar ID_0 = \"DD\";\n\nvar last_0=29;\n\nfunction on_off(mm,val)\n{\nif (val==0) { $(mm).height(\"30%\"); $(mm).css('background-color', '#f44336'); } //green\nif (val==1) { $(mm).height(\"60%\"); $(mm).css('background-color', '#4CAF50'); } //green\n}\n\nfunction feedback(text)\n{\n$(\"#info\"+ID_0).text(text);\nvar tm=setTimeout(function(){ $(\"#info\"+ID_0).text(\"Ok\"); clearTimeout(tm);}, 3000);\n}\n\nfunction selec_0(val,sta)\n{\nvar w=\"#td\"+val+ID_0;\n if (sta) $(w).css('background-color','#4CAF50'); else $(w).css('background-color','#FFC107');\n}\n\n\n    (function(scope){\n        scope.ID_0 = ID_0;\n        scope.send({payload: '29'})\n        scope.$watch('msg', function(msg) {\n            selec_0(last_0,0); last_0=msg.selector; selec_0(last_0,1);\n            for (var x=0; x<24; x++) \n                { \n                    var w=\"#t\"+x+ID_0; on_off(w,msg.timing[((msg.days-1)*24)+x]); \n                    var v=\"#v\"+x+ID_0; $(v).text(msg.timing[((msg.days-1)*24)+x] == 0 ? 'Off' : 'On')\n                } \n            for (var x=0; x<2; x++) { var w=\"#s\"+x+ID_0; $(w).text(msg.timing[168+x]); }\n             $(\"#d0\"+ID_0).text(thedays_0[msg.days-1]);\n             if ((last_0>4) &&(last_0<29))\n                 $(\"#current\"+ID_0).text(msg.timing[((msg.days-1)*24)+last_0-5]  == 0 ? 'Off' : 'On');\n             else\n                 $(\"#current\"+ID_0).text(\"-\");\n                 \n            if (msg.foryou!=\"\") { feedback(msg.foryou);  }\n            \n             \n        });\n \n    })(scope);\n      \n\n</script>\n<table width=\"100%\">\n    \n    <tr>\n        <td colspan=24><center><span class=\"smallheadings\" >Giorno</span></center></td>\n        <!--<td colspan=3><center><span class=\"smallheadings\">Clima</span></center></td>\n        <td colspan=3><center><span class=\"smallheadings\">Fuori casa</span></center></td>-->\n    </tr>\n   \n    <tr>\n        <td ng-click=\"send({payload: '29'})\" colspan=24><center><span id=\"{{ 'd0' + ID_0 }}\" style=\"cursor:pointer;color:white;font-size:120%\">LUNEDI</span></center></td>\n        <!--<td ng-click=\"send({payload: '1'})\" colspan=3><center><span id=\"s0\" style=\"color:white;font-size:120%\">14</span></center></td>\n        <td ng-click=\"send({payload: '2'})\" colspan=3><center><span id=\"s1\" style=\"color:white;font-size:120%\">20</span></center></td>-->\n    </tr>\n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td29' + ID_0 }}\" colspan=24 style=\"background-color:#9E9E9E;height:2px;\"></td>        \n       <!-- <td id=\"td1\" colspan=3 style=\"background-color:#9E9E9E;height:2px;\"></td>\n        <td id=\"td2\" colspan=3 style=\"background-color:#9E9E9E;height:2px;\"></td>-->\n    </tr>  \n\n    <tr>\n        <td ng-click=\"send({payload: '5'})\" class=\"thedays\"><span id=\"{{ 'v0' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't0' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '6'})\" class=\"thedays\"><span id=\"{{ 'v1' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't1' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '7'})\" class=\"thedays\"><span id=\"{{ 'v2' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't2' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '8'})\" class=\"thedays\"><span id=\"{{ 'v3' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't3' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '9'})\" class=\"thedays\"><span id=\"{{ 'v4' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't4' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '10'})\" class=\"thedays\"><span id=\"{{ 'v5' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't5' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '11'})\" class=\"thedays\"><span id=\"{{ 'v6' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't6' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '12'})\" class=\"thedays\"><span id=\"{{ 'v7' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't7' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '13'})\" class=\"thedays\"><span id=\"{{ 'v8' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't8' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '14'})\" class=\"thedays\"><span id=\"{{ 'v9' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't9' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '15'})\" class=\"thedays\"><span id=\"{{ 'v10' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't10' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '16'})\" class=\"thedays\"><span id=\"{{ 'v11' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't11' + ID_0 }}\" class=\"theblocks\"></div></td>\n    </tr>  \n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td5' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td6' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td7' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td8' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td9' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td10' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td11' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td12' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td13' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td14' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td15' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td16' + ID_0 }}\" class=\"the2px\"></td>\n    </tr>   \n    \n    <tr>\n        <td align=\"center\">0</td>\n        <td align=\"center\">1</td>\n        <td align=\"center\">2</td>\n        <td align=\"center\">3</td>\n        <td align=\"center\">4</td>\n        <td align=\"center\">5</td>\n        <td align=\"center\">6</td>\n        <td align=\"center\">7</td>\n        <td align=\"center\">8</td>\n        <td align=\"center\">9</td>\n        <td align=\"center\">10</td>\n        <td align=\"center\">11</td>\n    </tr> \n    \n    <tr>\n        <td ng-click=\"send({payload: '17'})\" class=\"thedays\"><span id=\"{{ 'v12' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't12' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '18'})\" class=\"thedays\"><span id=\"{{ 'v13' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't13' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '19'})\" class=\"thedays\"><span id=\"{{ 'v14' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't14' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '20'})\" class=\"thedays\"><span id=\"{{ 'v15' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't15' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '21'})\" class=\"thedays\"><span id=\"{{ 'v16' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't16' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '22'})\" class=\"thedays\"><span id=\"{{ 'v17' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't17' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '23'})\" class=\"thedays\"><span id=\"{{ 'v18' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't18' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '24'})\" class=\"thedays\"><span id=\"{{ 'v19' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't19' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '25'})\" class=\"thedays\"><span id=\"{{ 'v20' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't20' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '26'})\" class=\"thedays\"><span id=\"{{ 'v21' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't21' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '27'})\" class=\"thedays\"><span id=\"{{ 'v22' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't22' + ID_0 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '28'})\" class=\"thedays\"><span id=\"{{ 'v23' + ID_0 }}\" class=\"thetemps\"></span><div id=\"{{ 't23' + ID_0 }}\" class=\"theblocks\"></div></td>\n    </tr>  \n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td17' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td18' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td19' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td20' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td21' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td22' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td23' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td24' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td25' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td26' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td27' + ID_0 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td28' + ID_0 }}\" class=\"the2px\"></td>\n    </tr>  \n    \n    <tr>\n        <td align=\"center\">12</td>\n        <td align=\"center\">13</td>\n        <td align=\"center\">14</td>\n        <td align=\"center\">15</td>\n        <td align=\"center\">16</td>\n        <td align=\"center\">17</td>\n        <td align=\"center\">18</td>\n        <td align=\"center\">19</td>\n        <td align=\"center\">20</td>\n        <td align=\"center\">21</td>\n        <td align=\"center\">22</td>\n        <td align=\"center\">23</td>\n    </tr> \n    \n    <tr height=\"20px\">\n        <td colspan=2 class=\"smallheadings\">Azioni:</td>\n\n        <td colspan=10 ><center><span id=\"{{ 'info' + ID_0 }}\" class=\"smallheadings\" ></span></center></td>\n\n    </tr>\n    \n    <tr height=\"10px\">\n        <td colspan=\"12\"></td>\n    </tr>\n\n    <tr style=\"height:48px\">\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'd'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"keyboard_arrow_down\"></ng-md-icon>\n            </button> \n        </td>\n        \n        <td colspan=2><center><span id=\"{{ 'current' + ID_0 }}\" style=\"color:white;font-size:120%\">-</span></center></td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'u'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"keyboard_arrow_up\"></ng-md-icon>\n            </button> \n        </td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'r'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"content_copy\">\n                    <md-tooltip md-direction=\"bottom\">COPIA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 's'})\"> \n                 <ng-md-icon style=\"color: #fff;\" icon=\"save\">\n                    <md-tooltip md-direction=\"bottom\">SALVA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\"  ng-click=\"send({payload: 'c'})\"> \n                 <ng-md-icon style=\"color: #fff;\" icon=\"cancel\">\n                    <md-tooltip md-direction=\"bottom\">ANNULLA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n        <td colspan=1></td>\n    </tr>\n\n</table>","storeOutMessages":false,"fwdInMessages":false,"x":385,"y":1322,"wires":[["bf082093.4c803"]]},{"id":"bf082093.4c803","type":"function","z":"90cc983a.804858","name":"Process controls","func":"if ( typeof context.days_0 == 'undefined' ) context.days_0=1;\nif ( typeof context.selector_0 == 'undefined' ) context.selector_0=29;\nif ( typeof context.saving_0 == 'undefined' ) context.saving_0=1;\nif ( typeof context.global.timing_0 == 'undefined' ) \n    {\n        context.global.timing_0=[\n                        1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,\n                        1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,\n                        1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,\n                        1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,\n                        1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,\n                        1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,\n                        1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,\n                        6,1\n                        ];\n        context.saving_0=1;                    \n    }\nvar timing_0=global.get(\"timing_0\");\n\nswitch (msg.payload)\n    {\n    case \"u\" :  if ((context.selector_0>4)&&(context.selector_0<29))\n                {\n                    timing_0[((context.days_0-1)*24)+context.selector_0-5] = 1; \n                    msg.foryou=\"ON\";\n                }\n                if (context.selector_0==29) { msg.foryou=\"Giorno successivo\"; context.days_0++; if (context.days_0>7) { context.days_0 = 1; } }\n                break;\n    case \"d\" :  if ((context.selector_0>4)&&(context.selector_0<29))\n                {\n                    timing_0[((context.days_0-1)*24)+context.selector_0-5] = 0; \n                    msg.foryou=\"OFF\";\n                }\n                if (context.selector_0==29) {  msg.foryou=\"Giorno precedente\";  context.days_0--; if (context.days_0 < 1) { context.days_0 = 7;  } }\n                break;\n    case 'r' :  if ((context.selector_0>=5)&&(context.selector_0<28))\n                        {\n                         timing_0[((context.days_0-1)*24)+context.selector_0-4]=timing_0[((context.days_0-1)*24)+context.selector_0-5];   \n                         context.selector_0++;\n                         msg.foryou=\"Valore copiato nello slot successivo\";\n                        }\n                if ((context.selector_0==29)&&(context.days_0<7))\n                        {\n                         for (var a=0;a<24;a++)\n                            {\n                             timing_0[((context.days_0)*24)+a]=timing_0[((context.days_0-1)*24)+a];   \n                            }\n                         context.days_0++;\n                         msg.foryou=\"Impostazioni copiate nel giorno successivo\";\n                        }\n                        else if(context.days_0==7)\n                            msg.foryou=\"Fine della settimana raggiunto!\";\n                break;\n    case 's': context.saving_0=0;  msg.foryou=\"Impostazioni salvate\"; break;\n    case '1':\n    case '2':\n    case '3':\n    case '4':\n    case '5':\n    case '6':\n    case '7':\n    case '8':\n    case '9':\n    case '10':\n    case '11':\n    case '12':\n    case '13':\n    case '1':\n    case '15':\n    case '16':\n    case '17':\n    case '18':\n    case '19':\n    case '20':\n    case '21':\n    case '22':\n    case '23':\n    case '24':\n    case '25':\n    case '26':\n    case '27':\n    case '28':\n    case '29': context.selector_0=parseInt(msg.payload);\n               if (msg.payload=='29') msg.foryou=\"Giorno selezionato\";\n               else  msg.foryou=\"Regolazione accensione ore: \" + (parseInt(msg.payload)-5);\n    break;\n    case 'c' : msg.payload=\"niente\";  msg.foryou=\"Cambiamenti annullati\"; node.send([null,null,msg]);\n    }\n\nmsg.temperatures=context.temperatures_0;\nmsg.timing=timing_0;\nmsg.days=context.days_0;\nmsg.selector=context.selector_0;\n\nnode.send([msg,null,null]);\n\nif (context.saving_0===0) \n    { \n       msg.topic=\"\";\n        msg.timing=\"\";\n        msg.payload=JSON.stringify(timing_0);\n        node.send([null,msg,null]); \n        context.saving_0=1;\n    }\n    msg.foryou=\"\"","outputs":"3","noerr":0,"x":608,"y":1374,"wires":[["c6aaaa97.9d2138"],["7bdd4a33.21f714"],["464ee351.ba883c"]]},{"id":"57a2d99b.9d1e28","type":"inject","z":"90cc983a.804858","name":"Once only","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":true,"x":393,"y":1422,"wires":[["bf082093.4c803","96a337ab.9dd208"]]},{"id":"b183782e.cfa588","type":"inject","z":"90cc983a.804858","name":"Every minute","topic":"","payload":"","payloadType":"str","repeat":"60","crontab":"","once":true,"x":366,"y":1543,"wires":[["49c192d2.21910c"]]},{"id":"c2b276d.3897a88","type":"function","z":"90cc983a.804858","name":"Process heat","func":"var timing=global.get(\"timing_0\");\nvar now = new Date(msg.time);\nmsg.payload=timing[(now.getDay()*24)+now.getHours()];\nmsg.frost=timing[168];\nmsg.away=timing[169];\nnode.status({fill:\"blue\",shape:\"dot\",text: \"State: \" + msg.payload === 0 ? 'OFF' : 'ON'});\nreturn msg;\n\n","outputs":1,"noerr":0,"x":694,"y":1542,"wires":[["b7707faa.ba896"]]},{"id":"7bdd4a33.21f714","type":"file","z":"90cc983a.804858","name":"backup","filename":"/home/pi/data/on_off_scheduler.log","appendNewline":true,"createDir":true,"overwriteFile":"true","x":797,"y":1373,"wires":[]},{"id":"96a337ab.9dd208","type":"file in","z":"90cc983a.804858","name":"Restore","filename":"/home/pi/data/on_off_scheduler.log","format":"utf8","x":586,"y":1452,"wires":[["e527a20a.4449a"]]},{"id":"e527a20a.4449a","type":"function","z":"90cc983a.804858","name":"Restore data from SD","func":"context.global.timing_0=JSON.parse(msg.payload);\nmsg.payload=\"\";\nreturn msg;","outputs":1,"noerr":0,"x":786,"y":1452,"wires":[["fb292dd6.88b8d"]]},{"id":"b7707faa.ba896","type":"debug","z":"90cc983a.804858","name":"","active":true,"console":"false","complete":"true","x":863.5,"y":1542,"wires":[]},{"id":"603e1325.49d4ec","type":"link in","z":"90cc983a.804858","name":"restore","links":["464ee351.ba883c"],"x":446.5,"y":1473,"wires":[["96a337ab.9dd208"]]},{"id":"464ee351.ba883c","type":"link out","z":"90cc983a.804858","name":"restore","links":["603e1325.49d4ec"],"x":759.5,"y":1410,"wires":[]},{"id":"ee5f7e0b.b047e","type":"link in","z":"90cc983a.804858","name":"restoreSD","links":["fb292dd6.88b8d"],"x":446,"y":1374,"wires":[["bf082093.4c803"]]},{"id":"fb292dd6.88b8d","type":"link out","z":"90cc983a.804858","name":"restoreSD","links":["ee5f7e0b.b047e"],"x":940,"y":1452,"wires":[]},{"id":"c6aaaa97.9d2138","type":"link out","z":"90cc983a.804858","name":"setSettings","links":["a9ac35bc.552708"],"x":760.5,"y":1334,"wires":[]},{"id":"a9ac35bc.552708","type":"link in","z":"90cc983a.804858","name":"setSettings","links":["c6aaaa97.9d2138"],"x":252.5,"y":1322,"wires":[["704b3b45.1f3124"]]},{"id":"49c192d2.21910c","type":"moment","z":"90cc983a.804858","name":"time","topic":"","input":"","inputType":"date","inTz":"UTC","adjAmount":"2","adjType":"hours","adjDir":"add","format":"","locale":"it_IT","output":"time","outputType":"msg","outTz":"UTC","x":531.5,"y":1543,"wires":[["c2b276d.3897a88"]]},{"id":"b6d017fa.163da8","type":"ui_template","z":"90cc983a.804858","group":"236e90ca.4e1d","name":"Settings page","order":3,"width":"6","height":"6","format":"<script>\n\nvar thedays2=[\"DOMENICA\",\"LUNEDI\",\"MARTEDI\",\"MERCOLEDI\",\"GIOVEDI\",\"VENERDI\",\"SABATO\"];\n\nvar ID2 = \"CC\";\n\nvar last2=29;\n\nfunction stat2(text)\n{\n$(\"#info\"+ID2).text(text);\nvar tm=setTimeout(function(){ $(\"#info\"+ID2).text(\"Ok\"); clearTimeout(tm);}, 3000);\n}\n\nfunction selec2(val,sta)\n{\nvar w=\"#td\"+val+ID2;\n if (sta) $(w).css('background-color','#4CAF50'); else $(w).css('background-color','#FFC107');\n}\n\n\n    (function(scope){\n        scope.ID2 = ID2;\n        scope.send({payload: '29'})\n        scope.$watch('msg', function(msg) {\n            selec2(last2,0); last2=msg.selector; selec2(last2,1);\n            for (var x=0; x<24; x++) \n                { \n                    var w=\"#t\"+x+ID2; bar(w,msg.timing[((msg.days-1)*24)+x]); \n                    var v=\"#v\"+x+ID2; $(v).text(msg.timing[((msg.days-1)*24)+x]+\"°\")\n                } \n            for (var x=0; x<2; x++) { var w=\"#s\"+x+ID2; $(w).text(msg.timing[168+x]); }\n             $(\"#d0\"+ID2).text(thedays2[msg.days-1]);\n             if ((last2>4) &&(last2<29))\n                 $(\"#current\"+ID2).text(msg.timing[((msg.days-1)*24)+last2-5] + \"°\");\n             else\n                 $(\"#current\"+ID2).text(\"-\");\n                 \n            if (msg.foryou!=\"\") { stat2(msg.foryou);  }\n            \n             \n        });\n \n    })(scope);\n      \n\n</script>\n<table width=\"100%\">\n    \n    <tr>\n        <td colspan=24><center><span class=\"smallheadings\" >Giorno</span></center></td>\n        <!--<td colspan=3><center><span class=\"smallheadings\">Clima</span></center></td>\n        <td colspan=3><center><span class=\"smallheadings\">Fuori casa</span></center></td>-->\n    </tr>\n   \n    <tr>\n        <td ng-click=\"send({payload: '29'})\" colspan=24><center><span id=\"{{ 'd0' + ID2 }}\" style=\"cursor:pointer;color:white;font-size:120%\">LUNEDI</span></center></td>\n        <!--<td ng-click=\"send({payload: '1'})\" colspan=3><center><span id=\"s0\" style=\"color:white;font-size:120%\">14</span></center></td>\n        <td ng-click=\"send({payload: '2'})\" colspan=3><center><span id=\"s1\" style=\"color:white;font-size:120%\">20</span></center></td>-->\n    </tr>\n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td29' + ID2 }}\" colspan=24 style=\"background-color:#9E9E9E;height:2px;\"></td>        \n       <!-- <td id=\"td1\" colspan=3 style=\"background-color:#9E9E9E;height:2px;\"></td>\n        <td id=\"td2\" colspan=3 style=\"background-color:#9E9E9E;height:2px;\"></td>-->\n    </tr>  \n\n    <tr>\n        <td ng-click=\"send({payload: '5'})\" class=\"thedays\"><span id=\"{{ 'v0' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't0' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '6'})\" class=\"thedays\"><span id=\"{{ 'v1' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't1' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '7'})\" class=\"thedays\"><span id=\"{{ 'v2' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't2' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '8'})\" class=\"thedays\"><span id=\"{{ 'v3' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't3' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '9'})\" class=\"thedays\"><span id=\"{{ 'v4' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't4' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '10'})\" class=\"thedays\"><span id=\"{{ 'v5' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't5' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '11'})\" class=\"thedays\"><span id=\"{{ 'v6' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't6' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '12'})\" class=\"thedays\"><span id=\"{{ 'v7' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't7' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '13'})\" class=\"thedays\"><span id=\"{{ 'v8' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't8' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '14'})\" class=\"thedays\"><span id=\"{{ 'v9' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't9' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '15'})\" class=\"thedays\"><span id=\"{{ 'v10' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't10' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '16'})\" class=\"thedays\"><span id=\"{{ 'v11' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't11' + ID2 }}\" class=\"theblocks\"></div></td>\n    </tr>  \n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td5' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td6' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td7' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td8' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td9' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td10' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td11' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td12' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td13' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td14' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td15' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td16' + ID2 }}\" class=\"the2px\"></td>\n    </tr>   \n    \n    <tr>\n        <td align=\"center\">0</td>\n        <td align=\"center\">1</td>\n        <td align=\"center\">2</td>\n        <td align=\"center\">3</td>\n        <td align=\"center\">4</td>\n        <td align=\"center\">5</td>\n        <td align=\"center\">6</td>\n        <td align=\"center\">7</td>\n        <td align=\"center\">8</td>\n        <td align=\"center\">9</td>\n        <td align=\"center\">10</td>\n        <td align=\"center\">11</td>\n    </tr> \n    \n    <tr>\n        <td ng-click=\"send({payload: '17'})\" class=\"thedays\"><span id=\"{{ 'v12' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't12' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '18'})\" class=\"thedays\"><span id=\"{{ 'v13' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't13' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '19'})\" class=\"thedays\"><span id=\"{{ 'v14' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't14' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '20'})\" class=\"thedays\"><span id=\"{{ 'v15' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't15' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '21'})\" class=\"thedays\"><span id=\"{{ 'v16' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't16' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '22'})\" class=\"thedays\"><span id=\"{{ 'v17' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't17' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '23'})\" class=\"thedays\"><span id=\"{{ 'v18' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't18' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '24'})\" class=\"thedays\"><span id=\"{{ 'v19' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't19' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '25'})\" class=\"thedays\"><span id=\"{{ 'v20' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't20' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '26'})\" class=\"thedays\"><span id=\"{{ 'v21' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't21' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '27'})\" class=\"thedays\"><span id=\"{{ 'v22' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't22' + ID2 }}\" class=\"theblocks\"></div></td>\n        <td ng-click=\"send({payload: '28'})\" class=\"thedays\"><span id=\"{{ 'v23' + ID2 }}\" class=\"thetemps\"></span><div id=\"{{ 't23' + ID2 }}\" class=\"theblocks\"></div></td>\n    </tr>  \n    \n    <tr style=\"height:2px\">\n        <td id=\"{{ 'td17' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td18' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td19' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td20' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td21' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td22' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td23' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td24' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td25' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td26' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td27' + ID2 }}\" class=\"the2px\"></td>\n        <td id=\"{{ 'td28' + ID2 }}\" class=\"the2px\"></td>\n    </tr>  \n    \n    <tr>\n        <td align=\"center\">12</td>\n        <td align=\"center\">13</td>\n        <td align=\"center\">14</td>\n        <td align=\"center\">15</td>\n        <td align=\"center\">16</td>\n        <td align=\"center\">17</td>\n        <td align=\"center\">18</td>\n        <td align=\"center\">19</td>\n        <td align=\"center\">20</td>\n        <td align=\"center\">21</td>\n        <td align=\"center\">22</td>\n        <td align=\"center\">23</td>\n    </tr> \n    \n    <tr height=\"20px\">\n        <td colspan=2 class=\"smallheadings\">Azioni:</td>\n\n        <td colspan=10 ><center><span id=\"{{ 'info' + ID2 }}\" class=\"smallheadings\" ></span></center></td>\n\n    </tr>\n    \n    <tr height=\"10px\">\n        <td colspan=\"12\"></td>\n    </tr>\n\n    <tr style=\"height:48px\">\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'd'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"keyboard_arrow_down\">\n                    <md-tooltip md-direction=\"bottom\">DECREMENTA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n        \n        <td colspan=2><center><span id=\"{{ 'current' + ID2 }}\" style=\"color:white;font-size:120%\">-</span></center></td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'u'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"keyboard_arrow_up\">\n                    <md-tooltip md-direction=\"bottom\">INCREMENTA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 'r'})\"> \n               <ng-md-icon style=\"color: #fff;\" icon=\"content_copy\">\n                    <md-tooltip md-direction=\"bottom\">COPIA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"send({payload: 's'})\"> \n                 <ng-md-icon style=\"color: #fff;\" icon=\"save\">\n                    <md-tooltip md-direction=\"bottom\">SALVA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n\n        <td colspan=2>\n            <button class=\"vibrate filled touched smallfont rounded greybuttons\"  ng-click=\"send({payload: 'c'})\"> \n                 <ng-md-icon style=\"color: #fff;\" icon=\"cancel\">\n                    <md-tooltip md-direction=\"bottom\">ANNULLA</md-tooltip>\n                </ng-md-icon>\n            </button> \n        </td>\n        <td colspan=1></td>\n    </tr>\n\n</table>","storeOutMessages":false,"fwdInMessages":false,"x":354,"y":905,"wires":[["88e4a065.23fa7"]]},{"id":"88e4a065.23fa7","type":"function","z":"90cc983a.804858","name":"Process controls","func":"if ( typeof context.days2 == 'undefined' ) context.days2=1;\nif ( typeof context.selector2 == 'undefined' ) context.selector2=29;\nif ( typeof context.saving2 == 'undefined' ) context.saving2=1;\nif ( typeof context.global.timing2 == 'undefined' ) \n    {\n        context.global.timing2=[\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,14,\n                        6,14\n                        ];\n        context.saving2=1;                    \n    }\nvar timing2=global.get(\"timing2\");\n\nswitch (msg.payload)\n    {\n    case \"u\" :  if ((context.selector2>4)&&(context.selector2<29))\n                {\n                    timing2[((context.days2-1)*24)+context.selector2-5]++; \n                    if (timing2[((context.days2-1)*24)+context.selector2-5]>26){ timing2[((context.days2-1)*24)+context.selector2-5]=26; msg.foryou=\"Limite raggiunto\";}\n                    else msg.foryou=\"Temperatura aumentata\";\n                }\n                if (context.selector2==1) { if (timing2[168+(context.selector2-1)]<26) {  timing2[168+(context.selector2-1)]++; msg.foryou=\"Temperatura clima aumentata di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector2==2) { if (timing2[168+(context.selector2-1)]<26) {  timing2[168+(context.selector2-1)]++; msg.foryou=\"Temperatura fuori casa aumentata di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector2==29) { msg.foryou=\"Giorno successivo\"; context.days2++; if (context.days2>7) { context.days2 = 1; } }\n                break;\n    case \"d\" :  if ((context.selector2>4)&&(context.selector2<29))\n                {\n                    timing2[((context.days2-1)*24)+context.selector2-5]--; \n                    if (timing2[((context.days2-1)*24)+context.selector2-5]<14){ timing2[((context.days2-1)*24)+context.selector2-5]=14; msg.foryou=\"Limite raggiunto\";}\n                    else msg.foryou=\"Temperatura decrementata\";\n                }\n                if (context.selector2==1) { if (timing2[168+(context.selector2-1)]>12) { timing2[168+(context.selector2-1)]--; msg.foryou=\"Temperatura clima diminuita di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector2==2) { if (timing2[168+(context.selector2-1)]>12) { timing2[168+(context.selector2-1)]--; msg.foryou=\"Temperatura fuori casa diminuita di 1°C\"; } else msg.foryou=\"Limite raggiunto\"; }\n                if (context.selector2==29) {  msg.foryou=\"Giorno precedente\";  context.days2--; if (context.days2 < 1) { context.days2 = 7;  } }\n                break;\n    case 'r' :  if ((context.selector2>=5)&&(context.selector2<28))\n                        {\n                         timing2[((context.days2-1)*24)+context.selector2-4]=timing2[((context.days2-1)*24)+context.selector2-5];   \n                         context.selector2++;\n                         msg.foryou=\"Temperatura copiata nello slot successivo\";\n                        }\n                if ((context.selector2==29)&&(context.days2<7))\n                        {\n                         for (var a=0;a<24;a++)\n                            {\n                             timing2[((context.days2)*24)+a]=timing2[((context.days2-1)*24)+a];   \n                            }\n                         context.days2++;\n                         msg.foryou=\"Impostazioni copiate nel giorno successivo\";\n                        }\n                        else if(context.days2==7)\n                            msg.foryou=\"Fine della settimana raggiunto!\";\n                break;\n    case 's': context.saving2=0;  msg.foryou=\"Impostazioni salvate\"; break;\n    case '1':\n    case '2':\n    case '3':\n    case '4':\n    case '5':\n    case '6':\n    case '7':\n    case '8':\n    case '9':\n    case '10':\n    case '11':\n    case '12':\n    case '13':\n    case '14':\n    case '15':\n    case '16':\n    case '17':\n    case '18':\n    case '19':\n    case '20':\n    case '21':\n    case '22':\n    case '23':\n    case '24':\n    case '25':\n    case '26':\n    case '27':\n    case '28':\n    case '29': context.selector2=parseInt(msg.payload);\n               if (msg.payload=='1') msg.foryou=\"Temperatura clima selezionata\"; \n               else if (msg.payload=='2') msg.foryou=\"Temperatura fuori casa selezionata\";\n               else if (msg.payload=='29') msg.foryou=\"Giorno selezionato\";\n               else  msg.foryou=\"Regolazione temperatura ore: \" + (parseInt(msg.payload)-5);\n    break;\n    case 'c' : msg.payload=\"niente\";  msg.foryou=\"Cambiamenti annullati\"; node.send([null,null,msg]);\n    }\n\nmsg.temperatures=context.temperatures2;\nmsg.timing=timing2;\nmsg.days=context.days2;\nmsg.selector=context.selector2;\n\nnode.send([msg,null,null]);\n\nif (context.saving2===0) \n    { \n       msg.topic=\"\";\n        msg.timing=\"\";\n        msg.payload=JSON.stringify(timing2);\n        node.send([null,msg,null]); \n        context.saving2=1;\n    }\n    msg.foryou=\"\"","outputs":"3","noerr":0,"x":577,"y":957,"wires":[["787260d9.66ad9"],["1cf6f89b.0d45f7"],["7cc9f964.94edb8"]]},{"id":"1376f982.4b3f46","type":"inject","z":"90cc983a.804858","name":"Once only","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":true,"x":362,"y":1005,"wires":[["88e4a065.23fa7","1fa5b8d5.a8f1a7"]]},{"id":"ff3e7711.dd7228","type":"inject","z":"90cc983a.804858","name":"Every minute","topic":"","payload":"","payloadType":"str","repeat":"60","crontab":"","once":true,"x":335,"y":1126,"wires":[["4551bad1.cec7f4"]]},{"id":"d4a44a33.0d3668","type":"function","z":"90cc983a.804858","name":"Process heat","func":"var timing=global.get(\"timing2\");\nvar now = new Date(msg.time);\nmsg.payload=timing[(now.getDay()*24)+now.getHours()];\nmsg.frost=timing[168];\nmsg.away=timing[169];\nnode.status({fill:\"blue\",shape:\"dot\",text:\"Set point \" + msg.payload + \"°C\"});\nreturn msg;\n\n","outputs":1,"noerr":0,"x":663,"y":1125,"wires":[["9c47a8c8.854af8"]]},{"id":"1cf6f89b.0d45f7","type":"file","z":"90cc983a.804858","name":"backup","filename":"/home/pi/data/thermo_scheduler_02.log","appendNewline":true,"createDir":true,"overwriteFile":"true","x":766,"y":956,"wires":[]},{"id":"1fa5b8d5.a8f1a7","type":"file in","z":"90cc983a.804858","name":"Restore","filename":"/home/pi/data/thermo_scheduler_02.log","format":"utf8","x":555,"y":1035,"wires":[["5bd619d6.24d808"]]},{"id":"5bd619d6.24d808","type":"function","z":"90cc983a.804858","name":"Restore data from SD","func":"context.global.timing2=JSON.parse(msg.payload);\nmsg.payload=\"\";\nreturn msg;","outputs":1,"noerr":0,"x":755,"y":1035,"wires":[["f47b6ebc.28d9b"]]},{"id":"9c47a8c8.854af8","type":"debug","z":"90cc983a.804858","name":"","active":true,"console":"false","complete":"true","x":831.5,"y":1126,"wires":[]},{"id":"427f8802.d22818","type":"link in","z":"90cc983a.804858","name":"restore","links":["7cc9f964.94edb8"],"x":415.5,"y":1056,"wires":[["1fa5b8d5.a8f1a7"]]},{"id":"7cc9f964.94edb8","type":"link out","z":"90cc983a.804858","name":"restore","links":["427f8802.d22818"],"x":728.5,"y":993,"wires":[]},{"id":"114e243a.951acc","type":"link in","z":"90cc983a.804858","name":"restoreSD","links":["f47b6ebc.28d9b"],"x":415,"y":957,"wires":[["88e4a065.23fa7"]]},{"id":"f47b6ebc.28d9b","type":"link out","z":"90cc983a.804858","name":"restoreSD","links":["114e243a.951acc"],"x":909,"y":1035,"wires":[]},{"id":"787260d9.66ad9","type":"link out","z":"90cc983a.804858","name":"setSettings","links":["393cb66c.d9602a"],"x":729.5,"y":917,"wires":[]},{"id":"393cb66c.d9602a","type":"link in","z":"90cc983a.804858","name":"setSettings","links":["787260d9.66ad9"],"x":221.5,"y":905,"wires":[["b6d017fa.163da8"]]},{"id":"4551bad1.cec7f4","type":"moment","z":"90cc983a.804858","name":"time","topic":"","input":"","inputType":"date","inTz":"UTC","adjAmount":"2","adjType":"hours","adjDir":"add","format":"","locale":"it_IT","output":"time","outputType":"msg","outTz":"UTC","x":500.5,"y":1126,"wires":[["d4a44a33.0d3668"]]},{"id":"cccb363c.b966b8","type":"comment","z":"90cc983a.804858","name":"EDIT","info":"Settings page:\n-thedays2\n-ID2\n-last2\n-bar2\n-stat2\n-selec2\n\nProcess controls\n-days2\n-selector2\n-saving2\n-timing2\n-temperatures2\n\nRestore data from SD\n-timing2\n\nProcess heat\n-timing2\n\nBackup/Restore File read\nchange name of the file .log","x":148.5,"y":39,"wires":[]},{"id":"9b8f575a.b741a8","type":"ui_group","z":"","name":"Stat","tab":"8eef0cc0.5b1bf","order":2,"disp":false,"width":"6"},{"id":"f0089344.b8ed1","type":"ui_group","z":"","name":"Ora","tab":"8eef0cc0.5b1bf","disp":false,"width":"6"},{"id":"f1a9197e.2dfc88","type":"ui_group","z":"","name":"Stat1","tab":"8eef0cc0.5b1bf","order":1,"disp":false,"width":"6"},{"id":"f59caa4c.0eb048","type":"ui_group","z":"","name":"ON OFF scheduler","tab":"8eef0cc0.5b1bf","disp":false,"width":"6"},{"id":"236e90ca.4e1d","type":"ui_group","z":"","name":"Stat2","tab":"8eef0cc0.5b1bf","disp":false,"width":"6"},{"id":"8eef0cc0.5b1bf","type":"ui_tab","z":"","name":"Schedulers","icon":"dashboard"}]
Created 10 years, 5 months ago
Updated 8 years, 7 months ago
Rating: 3 2
  • debug (x4)
  • file (x4)
  • file in (x4)
  • function (x12)
  • inject (x9)
  • link in (x12)
  • link out (x12)
  • moment (x5)
  • ui_group (x5)
  • ui_template (x5)
  • ui_text (x1)
  • ui
  • template
  • scheduler
  • dashboard
  • week
  • chrono
  • thermostat
  • weekend
  • scargill
