Finland, Helsinki - Real-time HSL transit map
A realtime transit map generated from the Helsinki transportation realtime MQTT stream, including rate limiting and WebSockets output.
[{"id":"e2195212.a4714","type":"mqtt in","z":"266e93fa.65ea04","name":"HSL open API","topic":"/hfp/journey/#","qos":"2","broker":"a7e4e343.855248","x":247.7452392578125,"y":209,"wires":[["68c08c01.967884"]]},{"id":"3dc8e41d.4f6cb4","type":"function","z":"266e93fa.65ea04","name":"Parse Vehicle","func":"var data = msg.payload;\n\nvar vehicle = {\n    name: data.VP.veh,\n    lat: data.VP.lat,\n    lon: data.VP.long,\n    icon: \"ship\",\n    iconColor: \"red\",\n    source: data.VP.source,\n    bearing: data.VP.hdg,\n    speed: data.VP.spd,\n    designation: data.VP.desi\n    //extrainfo: data.VP.desi,\n    //timeStamp: data.VP.tst\n};\n\nif (\n    vehicle.source === 'hsl helmi'\n    ||\n    vehicle.source === 'hsl roisto'\n    ) {\n    // bus\n    vehicle.icon = 'friend';\n    vehicle.iconColor = 'blue';\n    vehicle.layer = \"Bus\";\n} else if (\n    vehicle.source === 'hsl live'\n    ||\n    vehicle.source === 'sm5logger'\n    ) {\n    // Local trains/trams\n    vehicle.iconColor = 'green';\n    vehicle.layer = \"Train/tram\";\n} else if (vehicle.source === 'vr') {\n    // VR train (local)\n    vehicle.iconColor = 'chartreuse';\n    vehicle.layer = \"VR train (local)\";\n} else if (vehicle.source === 'meri-test.digitraffic.fi') {\n    // ferry\n    vehicle.iconColor = 'aqua';\n    vehicle.layer = \"Ferry\";\n} else {\n    node.error('Unknown source:' + vehicle.source);\n    node.error('Unknown designation:' + vehicle.designation);\n}\n\nmsg.topic = vehicle.name;\nmsg.payload = vehicle;\n\nreturn msg;","outputs":1,"noerr":0,"x":423.9952392578125,"y":311.25,"wires":[["5d7249be.1cd9d8","5467e8f0.ab2c18"]]},{"id":"5467e8f0.ab2c18","type":"debug","z":"266e93fa.65ea04","name":"","active":false,"console":"false","complete":"false","x":586.2452392578125,"y":251.353515625,"wires":[]},{"id":"68c08c01.967884","type":"json","z":"266e93fa.65ea04","name":"","x":347.2452392578125,"y":258.353515625,"wires":[["3dc8e41d.4f6cb4","dd715ade.0ffc3"]]},{"id":"5d7249be.1cd9d8","type":"worldmap","z":"266e93fa.65ea04","name":"","lat":"60","lon":"25","zoom":"10","layer":"OSM","cluster":"","maxage":"","usermenu":"hide","panit":"false","x":601.5,"y":363,"wires":[]},{"id":"dd715ade.0ffc3","type":"debug","z":"266e93fa.65ea04","name":"","active":false,"console":"false","complete":"false","x":488.5,"y":188,"wires":[]},{"id":"a7e4e343.855248","type":"mqtt-broker","broker":"mqtt.hsl.fi","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":15,"cleansession":true,"willQos":"0","birthQos":"0"}]
Created 8 years, 7 months ago
Updated 7 years, 6 months ago
  • debug (x2)
  • json (x1)
  • mqtt in (x1)
  • mqtt-broker (x1)
  • Transportation
  • Finland
  • helsinki
  • HSL
  • MQTT
  • Map
  • rate-limiting
  • proxy
  • real-time
