PaparazziBot_nodered
A raspberry Pi 3 that communicates with an ARM mbed with motor control to look for celebrities.
[{"id":"5d4e9bc0.c22ee4","type":"exec","z":"8f026b9e.9a8278","command":"raspistill -o /usr/lib/node_modules/node-red/public/campi/image1.jpg -q 5","addpay":true,"append":"","useSpawn":"","timer":"","name":"Smile click photo","x":361,"y":146.5,"wires":[[],["dd630fe0.effb5"],[]]},{"id":"2b82306.32705d","type":"file in","z":"8f026b9e.9a8278","name":"image1.jpg","filename":"/usr/lib/node_modules/node-red/public/campi/image1.jpg","format":"","x":402.5,"y":229,"wires":[["b2028380.70ceb"]]},{"id":"b2028380.70ceb","type":"function","z":"8f026b9e.9a8278","name":"Reading image","func":"msg.headers = {\n \"Content-Type\":\"image/jpeg\"\n};\n\nvar img = msg.payload;\ncontext.global.img = img;\nreturn msg;","outputs":1,"noerr":0,"x":564.5,"y":276,"wires":[["9d9a315e.58a1d"]]},{"id":"9d9a315e.58a1d","type":"visual-recognition-v3","z":"8f026b9e.9a8278","name":"Execute Face Detection","apikey":"__PWRD__","image-feature":"detectFaces","lang":"en","x":770.5,"y":328,"wires":[["7586b430.4a121c","11a75eb8.a11831","ec2e4bc4.01d768"]]},{"id":"7586b430.4a121c","type":"debug","z":"8f026b9e.9a8278","name":" Print Visual Recognition Result","active":true,"console":"false","complete":"result","x":1057,"y":395,"wires":[]},{"id":"dd630fe0.effb5","type":"delay","z":"8f026b9e.9a8278","name":"Delay","pauseType":"delay","timeout":"0.1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":535,"y":152,"wires":[["2b82306.32705d"]]},{"id":"fbfe9795.960ab8","type":"wiotp out","z":"8f026b9e.9a8278","authType":"d","qs":"false","qsDeviceId":"","deviceKey":"4771cca8.1c73f4","deviceType":"","deviceId":"","event":"event","format":"json","name":"Iot Output Pic Info to IBM Watson Cloud","x":1335,"y":322,"wires":[]},{"id":"11a75eb8.a11831","type":"function","z":"8f026b9e.9a8278","name":"Stringifiy msg.result","func":"msg = {\n    payload: JSON.stringify(msg.result)\n    \n}\nreturn msg;","outputs":1,"noerr":0,"x":1033,"y":325,"wires":[["fbfe9795.960ab8"]]},{"id":"c4d028d2.2a6c98","type":"wiotp in","z":"8f026b9e.9a8278","authType":"d","deviceKey":"4771cca8.1c73f4","deviceType":"","deviceId":"","command":"takeapic","commandType":"g","name":"Iot Receive Start Command","x":144,"y":63,"wires":[["4c2bc609.144388"]]},{"id":"970a0714.0f7398","type":"inject","z":"8f026b9e.9a8278","name":"Manual Start","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":127,"y":112,"wires":[["4c2bc609.144388"]]},{"id":"b3c79aa5.6cf6c8","type":"serial out","z":"8f026b9e.9a8278","name":"Serial Output to Mbed","serial":"884229bd.d500c8","x":957,"y":522,"wires":[]},{"id":"3adb6db7.5b38d2","type":"function","z":"8f026b9e.9a8278","name":"Determine Direction","func":"if (msg.payload[0] == 0x52) { \n    msg.payload = '3';\n} else if (msg.payload[0] == 0x4C) {\n    msg.payload = '2';\n} else if (msg.payload[0] == 0x46 ) {\n    msg.payload = '1';\n} else if (msg.payload[0] == 0x42) {\n    msg.payload = '4';\n} else if (msg.payload[0] == 0x53) {\n    msg.payload = '0';\n} \n\nreturn msg;","outputs":1,"noerr":0,"x":684,"y":498,"wires":[["b3c79aa5.6cf6c8"]]},{"id":"3c7b7eaa.7fbc62","type":"serial in","z":"8f026b9e.9a8278","name":"Take A Pic from Mbed","serial":"884229bd.d500c8","x":135,"y":330,"wires":[["71cc10d9.0a486"]]},{"id":"8e55d8d8.30aa68","type":"wiotp in","z":"8f026b9e.9a8278","authType":"d","deviceKey":"4771cca8.1c73f4","deviceType":"","deviceId":"","command":"+","commandType":"g","name":"Iot Receive Movement Commands","x":394,"y":464,"wires":[["3adb6db7.5b38d2"]]},{"id":"860ee866.53f878","type":"twitter out","z":"8f026b9e.9a8278","twitter":"","name":"Tweet","x":1200,"y":75,"wires":[]},{"id":"ec2e4bc4.01d768","type":"function","z":"8f026b9e.9a8278","name":"Tweet img data","func":"var mode = context.global.mode;\nvar celebArray;\n\nif (mode == \"Manual\") {\n    msg.payload = \"No face detected\";\n    for (var i = 0; i < msg.result[\"images\"][0][\"faces\"].length; i++) {\n        try {\n            var gender = \"Gender: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"gender\"][\"gender\"]);\n            var gscore = \"Gender Score: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"gender\"][\"score\"]);\n            var max = \"Max: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"age\"][\"max\"]);\n            var min = \"Min: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"age\"][\"min\"]);\n            var agescore = \"Age Score: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"age\"][\"score\"]);\n            try {\n                var celebrity = \"Celebrity Found! \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"identity\"][\"name\"]);    \n                msg.payload = msg.payload + celebrity + \"\\n\";\n                msg.media = context.global.img;\n            } catch(err) {\n                msg.payload = msg.payload + gender + \"\\n\" + gscore + \"\\nAge Range: \" + min + \" \" + max + \"\\n\" + agescore;\n            }\n        } catch(err) {\n            msg.payload = \"No face detected\";\n        }\n    }\n    return msg;\n} else {\n    var celeb = context.global.celeb;\n    msg.payload = \"No celebrity found\";\n    for (var i = 0; i < msg.result[\"images\"][0][\"faces\"].length; i++) {\n        try {\n            if (JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"identity\"][\"name\"])==(celeb)) {\n                var gender = \"Gender: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"gender\"][\"gender\"]);\n                var gscore = \"Gender Score: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"gender\"][\"score\"]);\n                var max = \"Max: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"age\"][\"max\"]);\n                var min = \"Min: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"age\"][\"min\"]);\n                var agescore = \"Age Score: \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"age\"][\"score\"]);\n                var celebrity = \"Celebrity Found! \" + JSON.stringify(msg.result[\"images\"][0][\"faces\"][i][\"identity\"][\"name\"]);\n                msg.payload = celebrity + \"\\n\" + gender + \"\\n\" + gscore + \"\\nAge Range: \" + min + \" \" + max + \"\\n\" + agescore;\n                msg.media = context.global.img;\n                return msg;\n            } else {\n                msg.payload = \"Wrong Celebrity\";\n            }\n            \n        } catch(err) {\n            msg.payload = \"No celebrity found\";\n        }\n    }\n    return msg;\n}    ","outputs":1,"noerr":0,"x":940,"y":118,"wires":[["860ee866.53f878","18c549fe.aa1d06","b827faf1.dfc4f8"]]},{"id":"71cc10d9.0a486","type":"function","z":"8f026b9e.9a8278","name":"Start Camera","func":"if (msg.payload[0] == \"P\") {\n    msg.payload = \"\";\n    return msg;\n}\n","outputs":1,"noerr":0,"x":342,"y":366,"wires":[["5d4e9bc0.c22ee4"]]},{"id":"4c2bc609.144388","type":"function","z":"8f026b9e.9a8278","name":"Initiate Camera","func":"msg.payload = \"\";\nvar mode = \"Manual\";\ncontext.global.mode = mode;\nreturn msg;","outputs":1,"noerr":0,"x":391,"y":66,"wires":[["5d4e9bc0.c22ee4"]]},{"id":"beeda734.3496d8","type":"serial out","z":"8f026b9e.9a8278","name":"Mbed Continue Auto Mode","serial":"884229bd.d500c8","x":1326,"y":228,"wires":[]},{"id":"d08cf8f4.1fcab8","type":"wiotp in","z":"8f026b9e.9a8278","authType":"d","deviceKey":"4771cca8.1c73f4","deviceType":"","deviceId":"","command":"Auto","commandType":"g","name":"Start Auto Mode","x":418,"y":670,"wires":[["ad55fb39.24a598"]]},{"id":"ad55fb39.24a598","type":"function","z":"8f026b9e.9a8278","name":"Determine Celebrity","func":"if (msg.payload[0] == 0x4A) {\n    var celeb = \"\\\"Jackie Chan\\\"\";\n    context.global.celeb = celeb;\n    context.global.mode = \"Auto\";\n    msg.payload = \"A\";\n    return msg;\n} else if (msg.payload[0] == 0x41) {\n    var celeb = \"\\\"Angelina Jolie\\\"\";\n    context.global.celeb = celeb;\n    context.global.mode = \"Auto\";\n    msg.payload = \"A\";\n    return msg;\n}  else if (msg.payload[0] == 0x48) {\n    var celeb = \"\\\"Hillary Rodham Clinton\\\"\";\n    context.global.celeb = celeb;\n    context.global.mode = \"Auto\";\n    msg.payload = \"A\";\n    return msg;\n}  else if (msg.payload[0] == 0x45) {\n    var celeb = \"\\\"Emma Watson\\\"\";\n    context.global.celeb = celeb;\n    context.global.mode = \"Auto\";\n    msg.payload = \"A\";\n    return msg;\n}  else if (msg.payload[0] == 0x58) {\n    var celeb = \"\\\"Barack Obama\\\"\";\n    context.global.celeb = celeb;\n    context.global.mode = \"Auto\";\n    msg.payload = \"A\";\n    return msg;\n} else if (msg.payload[0] == 0x43) {\n    var celeb = \"\\\"Leonardo DiCaprio\\\"\";\n    context.global.celeb = celeb;\n    context.global.mode = \"Auto\";\n    msg.payload = \"A\";\n    return msg;\n}","outputs":1,"noerr":0,"x":663,"y":676,"wires":[["c5bb13e7.a85d1"]]},{"id":"c5bb13e7.a85d1","type":"serial out","z":"8f026b9e.9a8278","name":"Mbed Start Auto Mode","serial":"884229bd.d500c8","x":929,"y":675,"wires":[]},{"id":"18c549fe.aa1d06","type":"function","z":"8f026b9e.9a8278","name":"Continue Auto Mode","func":"var mode = context.global.mode;\nvar celeb = context.global.celeb;\n\n    if (mode == \"Auto\") {\n        if (msg.payload == \"No celebrity found\") {\n            msg.payload = 'A';\n        } else if (msg.payload == \"Wrong Celebrity\") {\n            msg.payload = 'A';\n        } else {\n            msg.payload = 'D';\n        }\n        return msg;\n    }","outputs":1,"noerr":0,"x":1056,"y":227,"wires":[["beeda734.3496d8"]]},{"id":"b827faf1.dfc4f8","type":"debug","z":"8f026b9e.9a8278","name":"","active":true,"console":"false","complete":"false","x":1252,"y":145,"wires":[]},{"id":"4771cca8.1c73f4","type":"wiotp-credentials","z":"","name":"a2g6k39sl6r5","org":"73k64g","devType":"Raspberry_Pi3","devId":"Device02"},{"id":"884229bd.d500c8","type":"serial-port","z":"","serialport":"/dev/ttyACM0","serialbaud":"9600","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":false}]
Created 8 years ago
  • debug (x2)
  • delay (x1)
  • exec (x1)
  • file in (x1)
  • function (x8)
  • visual-recognition
  • serial
  • Raspberry-Pi3
  • mbed
  • twitter
