Raspberry PI eth0 static IP network configuration via Dashboard
This flows allows users to manually change and enable the static IP configuration of the Raspberry PI.
This flow reads configuration in /etc/dhcpcd.conf file and uses sed commands to enable static ip on eth0 interface end manually set the new static ip parameters.
If you have never edited the /etc/dhcpcd.conf file this flow will work without any problem, it expect to find something like this
#interface eth0
#static ip_address=192.168.1.xx/24
#static routers=192.168.1.xx
#static domain_name_servers=192.168.1.xx
or this
interface eth0
This flow reads the entire content of the /etc/dhcpcd.conf file and starts reading line by line. Once he find the line interface eth0 or #interface eth0 it starts to store actual configuration values until he finds a line that doesn't contain static. For this reason DON'T ADD BLANK LINES OR COMMENTS to the configuration file or this flow will not work as expected
The flow will edit this file using sed so be careful and make sure you set a valid configuration before reboot your Raspberry.
Buy Me A Coffee
Enjoy
[{"id":"2d2bd18e.3e4abe","type":"tab","label":"IP Settings","disabled":false,"info":""},{"id":"6a63b433.e2a73c","type":"exec","z":"2d2bd18e.3e4abe","command":"cat /etc/dhcpcd.conf","addpay":false,"append":"","useSpawn":"","timer":"","name":"","x":476,"y":179,"wires":[["3239ea8.73a1016"],[],[]]},{"id":"3239ea8.73a1016","type":"function","z":"2d2bd18e.3e4abe","name":"parse response","func":"var lines = msg.payload.split(\"\\n\");\nvar data = [];\n\nfor(var i=0; i< lines.length; i++){\n    if(lines[i].indexOf(\"interface eth0\") != -1)\n        break;\n}\n\n//check if interface eth0 is disabled\nif(i < lines.length && lines[i].indexOf(\"#\") >= 0) flow.set('disabled', true);\nelse flow.set('disabled', false);\n\nnode.send({topic:'interface eth0', payload:flow.get('disabled')})\n\ni++;\n\nfor(i; i< lines.length; i++){\n   \n   //new interface, not eth0\n   if(lines[i].indexOf(\"static\") == -1)\n    break;\n    \n    var tmp = lines[i].split(\"=\");\n    if(tmp.length==2){\n        var prop = tmp[0].split(' ')[1].trim();\n        var value = tmp[1].trim();\n        \n        flow.set(prop, value);\n        node.send({topic:prop, payload:value})\n    }\n} ","outputs":1,"noerr":0,"x":716,"y":166,"wires":[["3e969ca3.142384"]]},{"id":"3e969ca3.142384","type":"switch","z":"2d2bd18e.3e4abe","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"ip_address","vt":"str"},{"t":"eq","v":"routers","vt":"str"},{"t":"eq","v":"domain_name_servers","vt":"str"},{"t":"eq","v":"interface eth0","vt":"str"}],"checkall":"false","repair":false,"outputs":4,"x":888,"y":166,"wires":[["2d434d1f.145822"],["502308c7.25bef8"],["6a605c6d.329194","140df8ca.dea297"],["ba4f96ca.0f28b8"]]},{"id":"2d434d1f.145822","type":"ui_text_input","z":"2d2bd18e.3e4abe","name":"ip_address","label":"Indirizzo IP","group":"1cf52e38.3cfee2","order":2,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"ip_address","x":1130,"y":120,"wires":[["a825b0e4.2a051"]]},{"id":"502308c7.25bef8","type":"ui_text_input","z":"2d2bd18e.3e4abe","name":"router","label":"Router","group":"1cf52e38.3cfee2","order":3,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"routers","x":1109,"y":163,"wires":[["a825b0e4.2a051"]]},{"id":"6a605c6d.329194","type":"ui_text_input","z":"2d2bd18e.3e4abe","name":"dns","label":"DNS","group":"1cf52e38.3cfee2","order":4,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"domain_name_servers","x":1109,"y":206,"wires":[["a825b0e4.2a051"]]},{"id":"9ae462fb.d924d","type":"exec","z":"2d2bd18e.3e4abe","command":"sudo sed -i ","addpay":true,"append":"","useSpawn":"","timer":"","oldrc":false,"name":"","x":510,"y":320,"wires":[[],[],[]]},{"id":"1b55bbd2.2f6a74","type":"ui_button","z":"2d2bd18e.3e4abe","name":"reboot","group":"1cf52e38.3cfee2","order":5,"width":"3","height":"1","passthru":false,"label":"Reboot","color":"","bgcolor":"","icon":"","payload":"By pressing OK the device will be rebooted. If settings are wrong this may cause the device to be unreachable","payloadType":"str","topic":"","x":170,"y":480,"wires":[["846fb983.93f448"]]},{"id":"6da389d0.e8d598","type":"exec","z":"2d2bd18e.3e4abe","command":"sudo reboot","addpay":false,"append":"","useSpawn":"","timer":"","name":"","x":650,"y":480,"wires":[[],[],[]]},{"id":"d0341b01.217ee8","type":"ui_button","z":"2d2bd18e.3e4abe","name":"refresh","group":"1cf52e38.3cfee2","order":6,"width":"3","height":"1","passthru":false,"label":"Update","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":111.44442749023438,"y":247.33291149139404,"wires":[["fb34e190.3926a","c2728ad2.71ac48"]]},{"id":"fb34e190.3926a","type":"delay","z":"2d2bd18e.3e4abe","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":278.8888740539551,"y":247.44451141357422,"wires":[["6a63b433.e2a73c"]]},{"id":"c2728ad2.71ac48","type":"function","z":"2d2bd18e.3e4abe","name":"send commands","func":"var properties = flow.get(\"properties\");\n\nvar disabled = flow.get(\"disabled\") ? '#' : '';\n\nif(disabled == '#'){\n    //enable interface (replace only first occurance)\n    var command = `'0,/#interface eth0/s//interface eth0/g;' /etc/dhcpcd.conf`;\n    node.send({payload: command})\n}\n\nfor(var i=0;i<properties.length;i++){\n    var p = properties[i];\n    \n    var old_value = flow.get(p);\n    var new_value = flow.get(p+\"_new\") || old_value;\n    \n    if(old_value && ((old_value != new_value) || disabled == '#'))\n    {\n        //enable interface (replace only first occurance)\n        var command = `'0,\\\\?${disabled}static ${p}=${old_value}?s??static ${p}=${new_value}?g;' /etc/dhcpcd.conf`;\n        node.send({payload: command})\n    }\n}\n\n","outputs":1,"noerr":0,"x":300,"y":320,"wires":[["8d2915b0.eb5188","9ae462fb.d924d"]]},{"id":"846fb983.93f448","type":"ui_toast","z":"2d2bd18e.3e4abe","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"Cancel","topic":"ATTENTION","name":"","x":330,"y":480,"wires":[["9f141047.ed494"]]},{"id":"9f141047.ed494","type":"switch","z":"2d2bd18e.3e4abe","name":"OK ?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"OK","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":480,"wires":[["6da389d0.e8d598"]]},{"id":"a825b0e4.2a051","type":"function","z":"2d2bd18e.3e4abe","name":"store new","func":"flow.set(msg.topic+\"_new\", msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":1419,"y":161,"wires":[["aef2e472.475238"]]},{"id":"b585fb60.e936a8","type":"inject","z":"2d2bd18e.3e4abe","name":"init","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":122,"y":91,"wires":[["a6810bb0.a3e788"]]},{"id":"a6810bb0.a3e788","type":"function","z":"2d2bd18e.3e4abe","name":"set properties","func":"var properties = ['routers', 'ip_address', 'domain_name_servers'];\n\nflow.set(\"properties\", properties);\n\n//init properties\nfor(var i=0;i<properties.length;i++){\n    var p = properties[i];\n    flow.set(p, null);\n    flow.set(p+\"_new\", null);\n}\n\nnode.send({payload: true});\n","outputs":1,"noerr":0,"x":326,"y":91,"wires":[["6a63b433.e2a73c"]]},{"id":"8d2915b0.eb5188","type":"debug","z":"2d2bd18e.3e4abe","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":514,"y":385,"wires":[]},{"id":"fd5e6a37.bc5d38","type":"ui_toast","z":"2d2bd18e.3e4abe","position":"top right","displayTime":"3","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"","x":1310,"y":340,"wires":[]},{"id":"140df8ca.dea297","type":"change","z":"2d2bd18e.3e4abe","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"Settings updated. Reboot device to enable new ip","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1097,"y":310,"wires":[["fd5e6a37.bc5d38"]]},{"id":"ba4f96ca.0f28b8","type":"ui_text","z":"2d2bd18e.3e4abe","group":"1cf52e38.3cfee2","order":1,"width":0,"height":0,"name":"","label":"Static ip","format":"{{!msg.payload}}","layout":"row-spread","x":1120,"y":248,"wires":[]},{"id":"fea93690.140ec8","type":"ui_toast","z":"2d2bd18e.3e4abe","position":"top right","displayTime":"3","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"","x":1758,"y":161,"wires":[]},{"id":"aef2e472.475238","type":"change","z":"2d2bd18e.3e4abe","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"New setting stored ","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1566,"y":161,"wires":[["fea93690.140ec8"]]},{"id":"4b72781d.d0e178","type":"ui_text","z":"2d2bd18e.3e4abe","group":"1cf52e38.3cfee2","order":1,"width":0,"height":0,"name":"help","label":"","format":"To store the new value, once edited, press ENTER or TAB","layout":"col-center","x":711,"y":91,"wires":[]},{"id":"1cf52e38.3cfee2","type":"ui_group","z":"","name":"IP Settings","tab":"be53a269.02ec3","disp":true,"width":"6","collapse":false},{"id":"be53a269.02ec3","type":"ui_tab","z":"","name":"Settings","icon":"settings"}]
Created 7 years, 7 months ago
Rating: 3 2
  • change (x2)
  • delay (x1)
  • exec (x3)
  • function (x4)
  • switch (x2)
  • ui_button (x2)
  • ui_group (x1)
  • ui_text (x2)
  • ui_text_input (x3)
  • ui_toast (x3)
  • raspberry
  • raspberrypi
  • dashboard
  • network
  • configuration
  • ip
  • staticip
