Ask Fritz!Box who is at home
A flow, that asks fritz!box, who is at home. For that edit the mac list and add/remove persons from list. Edit the MAC for each user. Use for example the mac of the smartphone. At the end of the flow the presence is printed to the debug out. Also you can publish this to mqtt.
[{"id":"5ca38ebf.4e20b","type":"inject","z":"ca9fa2ba.c5628","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":140,"y":60,"wires":[["3dbffa8f.ffbc66"]]},{"id":"3dbffa8f.ffbc66","type":"function","z":"ca9fa2ba.c5628","name":"mac list","func":"macList = { \"bob\":\"12:12:12:12:12:12\",\n            \"linda\":\"34:34:34:34:34:34\",\n            \"paul\":\"56:56:56:56:56:56\" };\n\nmsg.payload = macList;\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":60,"wires":[["e75c1edd.22298"]]},{"id":"ab5e6f6e.1e689","type":"debug","z":"ca9fa2ba.c5628","name":"","active":true,"console":"false","complete":"true","x":730,"y":160,"wires":[]},{"id":"27775190.f7f8ce","type":"function","z":"ca9fa2ba.c5628","name":"frame data","func":"newMsg = { \"payload\": {\"NewMACAddress\": msg.payload},\n           \"hostname\": msg.parts.key };\n\nreturn newMsg;","outputs":1,"noerr":0,"x":610,"y":60,"wires":[["805f607a.cd5ea"]]},{"id":"e75c1edd.22298","type":"split","z":"ca9fa2ba.c5628","name":"","splt":"","x":450,"y":60,"wires":[["27775190.f7f8ce"]]},{"id":"805f607a.cd5ea","type":"fritzbox-in","z":"ca9fa2ba.c5628","device":"cb769716.cc9b48","name":"ask fritz.box","service":"urn:dslforum-org:service:Hosts:1","action":"GetSpecificHostEntry","arguments":"{\"NewMACAddress\":\"value\"}","x":330,"y":160,"wires":[["1f1586f3.a24d79"]]},{"id":"1f1586f3.a24d79","type":"function","z":"ca9fa2ba.c5628","name":"format output for mqtt","func":"msg = { \"payload\": msg.payload.NewActive,\n        \"topic\": \"human/presence/\" + msg.hostname };\nreturn msg;","outputs":1,"noerr":0,"x":540,"y":160,"wires":[["ab5e6f6e.1e689"]]},{"id":"cb769716.cc9b48","type":"fritzbox-config","z":"","name":"MyFritz","host":"fritz.box","port":"49000","ssl":false}]
coolchip
created 5 months ago
  • function (x3)
  • fritzbox
  • fritz!box
  • presence
