Smick_04_analog_output
Analog output example
        "id": "8687af10.572f9",
        "type": "tab",
        "label": "analog_output"
        "id": "490bf569.5df81c",
        "type": "ui_slider",
        "z": "8687af10.572f9",
        "label": "D2 PWM",
        "group": "9afd09b1.9a0ca8",
        "order": 2,
        "width": 0,
        "height": 0,
        "passthru": true,
        "topic": "",
        "min": "0",
        "max": "100",
        "step": "1",
        "x": 220,
        "y": 340,
                "39c62157.e0b85e"
        "id": "2b8ff9bd.7a7ec6",
        "type": "link out",
        "name": "command",
        "links": [
            "1096456f.bfc93b"
        "x": 775,
        "y": 340,
        "id": "b2d27b1b.4fa508",
        "type": "function",
        "name": "D2=n",
        "func": "msg.payload=\"d2=\"+msg.payload;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 650,
        "y": 340,
                "2b8ff9bd.7a7ec6"
        "id": "39c62157.e0b85e",
        "type": "range",
        "minin": "0",
        "maxin": "100",
        "minout": "0",
        "maxout": "1023",
        "action": "scale",
        "round": true,
        "name": "0..1023",
        "x": 420,
        "y": 340,
                "b2d27b1b.4fa508"
        "id": "d0a2ad0b.1ec3b",
        "type": "comment",
        "name": "analogic output (PWM)",
        "info": "",
        "x": 260,
        "y": 240,
        "id": "8e3013c5.d98f3",
        "type": "comment",
        "name": "Description",
        "info": "Smick_04_analog_output\n_______________________________________________________________________________\nPackage : Smick v.1\nModule  : console\nAuthor  : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate        Author  Description\n2016.12.17  Curci   genesis\n_______________________________________________________________________________\n\nDescription\n\nQuesto flusso costruisce un cruscotto contenente un nodo slider per regolare la luminosità del LED.\nI comandi generati sono inviati a smick tramite il flusso \"dasboard console\".\n\nThis flow builds a dashboard that contains a slider node to regulate the LED brightness.\nThe generated commands are sent to Smick through \"dasboard console\" flow\".\n_______________________________________________________________________________\n\nBill Of Material\n\nHardware:\n\n    1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n    1 Smick Wi-Fi connected to the internet\n    1 LED connected to smick \n\nHW Connections:\n\n    Device  pin     Smick pin\n    LED     +       D2\n    LED     -       GND\n\nFlow Connections:\n\n    console\n\nAccount:\n\n    Wi-Fi credentials\n    MQTT broker\n    FRED\n",
        "x": 220,
        "y": 140,
        "id": "9afd09b1.9a0ca8",
        "type": "ui_group",
        "z": "",
        "name": "analog",
        "tab": "f142a68c.ec9b78",
        "order": 2,
        "disp": true,
        "width": "6"
        "id": "f142a68c.ec9b78",
        "type": "ui_tab",
        "z": "",
        "name": "Output",
        "icon": "dashboard",
        "order": 2
infosmick
created 3 months ago
  • comment (x2)
  • range (x1)
  • link out (x1)
  • ui_group (x1)
  • ui_slider (x1)
