Smick_02_status
Status example
[{"id":"31e0a7cd.fa3838","type":"tab","label":"status"},{"id":"429b7532.4537cc","type":"ui_text","z":"31e0a7cd.fa3838","group":"8557c687.af1ee8","order":1,"width":0,"height":0,"name":"","label":"","format":"{{msg.payload}}","layout":"row-center","x":730,"y":200,"wires":[]},{"id":"6a993042.d9618","type":"switch","z":"31e0a7cd.fa3838","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"DISC","vt":"str"},{"t":"else"}],"checkall":"true","outputs":2,"x":350,"y":180,"wires":[["f02fa603.561938","48210721.75ecf8"],["d85aa277.4e1b6"]]},{"id":"f02fa603.561938","type":"change","z":"31e0a7cd.fa3838","name":"PING","rules":[{"t":"set","p":"payload","pt":"msg","to":"PING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":120,"wires":[["881b41f1.88da6"]]},{"id":"593d4ddb.8b7894","type":"link in","z":"31e0a7cd.fa3838","name":"event","links":["ca2d688.4211598"],"x":195,"y":180,"wires":[["6a993042.d9618"]]},{"id":"881b41f1.88da6","type":"link out","z":"31e0a7cd.fa3838","name":"command","links":["1096456f.bfc93b"],"x":915,"y":120,"wires":[]},{"id":"48210721.75ecf8","type":"change","z":"31e0a7cd.fa3838","name":"disconnected","rules":[{"t":"set","p":"payload","pt":"msg","to":"disconnected","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":180,"wires":[["429b7532.4537cc"]]},{"id":"d85aa277.4e1b6","type":"change","z":"31e0a7cd.fa3838","name":"connected","rules":[{"t":"set","p":"payload","pt":"msg","to":"connected","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":240,"wires":[["429b7532.4537cc"]]},{"id":"f5d2f0c4.a111f","type":"comment","z":"31e0a7cd.fa3838","name":"Description","info":"Smick_02_status\n_______________________________________________________________________________\nPackage : Smick v.1\nModule  : status\nAuthor  : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate        Author  Description\n2016.12.26  Curci   genesis\n_______________________________________________________________________________\n\nDescription\n\ntodo\n\n_______________________________________________________________________________\n\nBill Of Material\n\nHardware:\n\n    1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n    1 Smick Wi-Fi connected to the internet\n\nHW Connections:\n\n    None.\n\nFlow Connections:\n\n    console\n\nAccount:\n\n    Wi-Fi router\n    MQTT broker\n    FRED\n","x":140,"y":60,"wires":[]},{"id":"772a2c1a.7cc8a4","type":"ui_button","z":"31e0a7cd.fa3838","name":"","group":"8557c687.af1ee8","order":2,"width":0,"height":0,"label":"reset","color":"","icon":"","payload":"RESET","payloadType":"str","topic":"","x":730,"y":260,"wires":[["881b41f1.88da6"]]},{"id":"8557c687.af1ee8","type":"ui_group","z":"","name":"status","tab":"ab80aedb.3888e","order":2,"disp":true,"width":"6"},{"id":"ab80aedb.3888e","type":"ui_tab","z":"","name":"Console","icon":"dashboard","order":1}]
Created 7 years, 11 months ago
  • change (x3)
  • link in (x1)
  • link out (x1)
  • switch (x1)
  • ui_button (x1)
  • ui_group (x1)
  • ui_text (x1)
