Data Log Weather SQLite
This is a simple flow which will get the weather information whenever it changes and extract the temperature in Celsius, humidity, look, details about the look.
For this a Database file is created with name as weather
Database Structure:
weather [Filename] | |======temperature [tablename] | |==== date [col 1] |==== temperature [col 2] |==== humidity [col 3] |==== look [col 4] |==== detail [col 5]
the moment node is used for the date. and the date format is date month year without space.
any changes in the weather information will triggers a data injection.
since only 4 data was taken for storage its possible that same information can be stored twice because of the change of the hidden values.
An another version with Dashboard and retrieval will be added soon.
required nodes: [other than base nodes]
sqlite http://flows.nodered.org/node/node-red-node-sqlite moment http://flows.nodered.org/node/node-red-contrib-moment
[{"id":"9cb4c385.634b4","type":"sqlitedb","db":"/home/karthhic/weather"},{"id":"2c320d48.59ff02","type":"openweathermap in","name":"","lon":"","lat":"","city":"Tampere","country":"Finland","x":86.5,"y":388,"z":"7ed71e0a.377cd8","wires":[["da4a1d3f.077c8"]]},{"id":"537e7081.111108","type":"debug","name":"","active":true,"console":"false","complete":"topic","x":708,"y":388,"z":"7ed71e0a.377cd8","wires":[]},{"id":"6e7cc218.88ea54","type":"template","name":"","field":"topic","format":"handlebars","template":"INSERT INTO temperature (date,temperature,humidity,look,detail)\nVALUES ({{date}},{{payload.tempc}},{{payload.humidity}},\"{{payload.weather}}\",\"{{payload.detail}}\");","x":446,"y":389,"z":"7ed71e0a.377cd8","wires":[["88876ba0.6da6f8"]]},{"id":"da4a1d3f.077c8","type":"moment","name":"","topic":"","input":"payload","format":"DDMMYY","locale":"","output":"date","x":283,"y":387,"z":"7ed71e0a.377cd8","wires":[["6e7cc218.88ea54"]]},{"id":"88876ba0.6da6f8","type":"sqlite","mydb":"9cb4c385.634b4","name":"db","x":571,"y":388,"z":"7ed71e0a.377cd8","wires":[["537e7081.111108"]]}]
Created 11 years, 6 months ago
Updated 11 years, 3 months ago
  • template (x1)
  • weather
  • sqlite
  • log
