Raspberry Pi Control Dashboard
Requirement: node-red-dashboard. Obviously you will need a Raspberry Pi too!
This is a simple but very useful dashboard to control a Raspberry Pi (similar to Cayenne dashboard for RPi), it includes so far:
  • CPU Temperature
  • CPU Load %
  • Free RAM %
  • Disk Usage %
  • Actions: Shutdown and Reboot buttons
Feel free to fork and and more stuff ;-) You can get some info and screenshots here
[{"id":"2653a0b0.26d638","type":"ui_gauge","z":"a9ef8731.662048","name":"","group":"1890881e.83819","order":2,"width":0,"height":0,"gtype":"gage","title":"CPU Temperature","label":"C","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"x":730,"y":140,"wires":[]},{"id":"fba68adf.14e13","type":"exec","z":"a9ef8731.662048","command":"vcgencmd measure_temp","addpay":false,"append":"","useSpawn":"","timer":"","name":"RPi Temp.","x":370,"y":140,"wires":[["fa5b499.e176cb8"],[],[]]},{"id":"7c8379de.068868","type":"inject","z":"a9ef8731.662048","name":"","topic":"","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"x":164.5,"y":148.25,"wires":[["fba68adf.14e13","972ece2a.3dbe8","6242be99.26ac88"]]},{"id":"fa5b499.e176cb8","type":"function","z":"a9ef8731.662048","name":"","func":"str = msg.payload\nmsg.payload = str.substring(5,9);\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":140,"wires":[["2653a0b0.26d638","28b64a2c.b32116"]]},{"id":"683a2b05.736204","type":"ui_button","z":"a9ef8731.662048","name":"","group":"c5f1b8aa.45bc08","order":2,"width":0,"height":0,"label":"Reboot","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":140,"y":520,"wires":[["1cf31554.2aaa63"]]},{"id":"1cf31554.2aaa63","type":"exec","z":"a9ef8731.662048","command":"sudo reboot","addpay":false,"append":"","useSpawn":"","timer":"","name":"Reboot","x":358,"y":520,"wires":[[],[],[]]},{"id":"38e53dbf.ca594a","type":"ui_button","z":"a9ef8731.662048","name":"","group":"c5f1b8aa.45bc08","order":3,"width":0,"height":0,"label":"Shutdown","color":"","bgcolor":"red","icon":"","payload":"","payloadType":"str","topic":"","x":148.5,"y":564.25,"wires":[["c409cae5.8e4128"]]},{"id":"c409cae5.8e4128","type":"exec","z":"a9ef8731.662048","command":"sudo shutdown -h now","addpay":false,"append":"","useSpawn":"","timer":"","name":"Shutdown","x":369.5,"y":582.25,"wires":[[],[],[]]},{"id":"28b64a2c.b32116","type":"ui_chart","z":"a9ef8731.662048","name":"","group":"1890881e.83819","order":3,"width":0,"height":0,"label":"","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","ymin":"","ymax":"","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"x":730,"y":180,"wires":[[],[]]},{"id":"972ece2a.3dbe8","type":"exec","z":"a9ef8731.662048","command":"top -d 0.5 -b -n2 | grep \"Cpu(s)\"|tail -n 1 | awk '{print $2 + $4}'","addpay":false,"append":"","useSpawn":"","timer":"","name":"CPU Load","x":370,"y":220,"wires":[["b9372186.ed1a5"],[],[]]},{"id":"6242be99.26ac88","type":"exec","z":"a9ef8731.662048","command":"free | grep Mem | awk '{print 100*($4+$6+$7)/$2}'","addpay":false,"append":"","useSpawn":"","timer":"","name":"Free Memory","x":370,"y":300,"wires":[["9b301b09.8c0468"],[],[]]},{"id":"b9372186.ed1a5","type":"ui_gauge","z":"a9ef8731.662048","name":"","group":"1890881e.83819","order":1,"width":0,"height":0,"gtype":"gage","title":"Processor","label":"CPU","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"x":730,"y":220,"wires":[]},{"id":"9b301b09.8c0468","type":"ui_gauge","z":"a9ef8731.662048","name":"","group":"9a96a8b1.92db78","order":1,"width":0,"height":0,"gtype":"gage","title":"Memory","label":"RAM","format":"{{value.toFixed(1)}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"x":730,"y":300,"wires":[]},{"id":"270f61f0.9af05e","type":"exec","z":"a9ef8731.662048","command":"df -h","addpay":false,"append":"","useSpawn":"","timer":"","name":"Disk Usage","x":370,"y":380,"wires":[["d70b7556.a0a9e"],[],[]]},{"id":"7ca6ecb.7512014","type":"ui_gauge","z":"a9ef8731.662048","name":"","group":"72fc319.cc425d","order":1,"width":0,"height":0,"gtype":"gage","title":"Disk","label":"Usage","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"x":730,"y":380,"wires":[]},{"id":"d70b7556.a0a9e","type":"function","z":"a9ef8731.662048","name":"","func":"var re = /([0-9]{2})%/\nvar idx = msg.payload.search(re);\nvar str = msg.payload;\nif (idx >=0) {\n    str = msg.payload.substring(idx, idx + 2);\n}\nmsg.payload = str;\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":380,"wires":[["7ca6ecb.7512014"]]},{"id":"59103f97.07fed","type":"inject","z":"a9ef8731.662048","name":"","topic":"","payload":"","payloadType":"date","repeat":"60","crontab":"","once":false,"x":170,"y":380,"wires":[["270f61f0.9af05e"]]},{"id":"1890881e.83819","type":"ui_group","z":"","name":"Col1","tab":"c3173234.2636e","order":1,"disp":false,"width":"6"},{"id":"c5f1b8aa.45bc08","type":"ui_group","z":"","name":"Actions","tab":"c3173234.2636e","order":4,"disp":true,"width":"6"},{"id":"9a96a8b1.92db78","type":"ui_group","z":"","name":"Col2","tab":"c3173234.2636e","order":2,"disp":false,"width":"6"},{"id":"72fc319.cc425d","type":"ui_group","z":"","name":"Col3","tab":"c3173234.2636e","order":3,"disp":false,"width":"6"},{"id":"c3173234.2636e","type":"ui_tab","z":"","name":"RPi Control","icon":"dashboard","order":1}]
Created 7 years, 9 months ago
Updated 3 years, 9 months ago
Rating: 5 2
  • exec (x6)
  • function (x2)
  • inject (x2)
  • ui_button (x2)
  • ui_chart (x1)
  • ui_gauge (x4)
  • ui_group (x4)
  • raspberrypi
  • dashboard
