MicroPi Microphone Wav-Filewriter [Demo Flow]
A simple Demo to show how to use the MicroPi Node as well as the the Microphone Node in combination with the Wav-Filewriter Node to record Audio Files on a Raspberry Pi with an external USB interface.
[{"id":"a05c1517.d1b518","type":"microPi","z":"97d0e573.552e58","name":"microPi","filename":"/home/pi/audio/demo.wav","domain":"http://localhost:1880/getAudio","rate":"16000","bitwidth":"16","endian":"little","encoding":"signed-integer","channels":"1","silence":"5","debug":"false","mode":"","x":500,"y":240,"wires":[["242b3c43.2ee8c4"],["2312eb0a.f1b494"],["f3a1701c.f7b0e"]]},{"id":"cf008b0c.048058","type":"inject","z":"97d0e573.552e58","name":"record","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"x":150,"y":180,"wires":[["a05c1517.d1b518"]]},{"id":"12db4a9.adbb7b5","type":"inject","z":"97d0e573.552e58","name":"stop","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"x":150,"y":220,"wires":[["a05c1517.d1b518"]]},{"id":"5769f387.a1d7bc","type":"http in","z":"97d0e573.552e58","name":"","url":"/record","method":"post","swaggerDoc":"","x":150,"y":280,"wires":[["774db6b2.a11ab8"]]},{"id":"34ad42f1.0ff19e","type":"http in","z":"97d0e573.552e58","name":"","url":"/stop","method":"post","swaggerDoc":"","x":140,"y":320,"wires":[["774db6b2.a11ab8"]]},{"id":"774db6b2.a11ab8","type":"function","z":"97d0e573.552e58","name":"","func":"if(msg.payload.recording == \"true\") {\n    return {payload:true};\n} else if(msg.payload.recording == \"false\"){\n    return {payload:false};\n}\n","outputs":1,"noerr":0,"x":310,"y":300,"wires":[["a05c1517.d1b518"]]},{"id":"242b3c43.2ee8c4","type":"debug","z":"97d0e573.552e58","name":"Raw L16 Wave Stream","active":false,"console":"false","complete":"true","x":750,"y":200,"wires":[]},{"id":"2312eb0a.f1b494","type":"debug","z":"97d0e573.552e58","name":"Wav File as a Buffer and metadata","active":false,"console":"false","complete":"true","x":780,"y":240,"wires":[]},{"id":"f3a1701c.f7b0e","type":"debug","z":"97d0e573.552e58","name":"Status Messages","active":false,"console":"false","complete":"true","x":730,"y":280,"wires":[]},{"id":"60d2b323.dcc4bc","type":"http in","z":"97d0e573.552e58","name":"","url":"/getAudio/","method":"get","swaggerDoc":"","x":160,"y":660,"wires":[["b1982777.ba6068"]]},{"id":"b1982777.ba6068","type":"file in","z":"97d0e573.552e58","name":"","filename":"/home/pi/audio/demo.wav","format":"","x":430,"y":660,"wires":[["a84ae484.d92378"]]},{"id":"a84ae484.d92378","type":"http response","z":"97d0e573.552e58","name":"","x":690,"y":660,"wires":[]},{"id":"447d5e57.866d7","type":"rpi-gpio in","z":"97d0e573.552e58","name":"","pin":"7","intype":"down","debounce":"1000","read":true,"x":130,"y":380,"wires":[["af5c03d6.f7574"]]},{"id":"af5c03d6.f7574","type":"function","z":"97d0e573.552e58","name":"","func":"if(msg.payload === 1)\n{ return {payload:true}; } \nelse \n{ return {payload:false}; }","outputs":1,"noerr":0,"x":310,"y":380,"wires":[["a05c1517.d1b518"]]},{"id":"d4606eb3.2b755","type":"comment","z":"97d0e573.552e58","name":"MicroPi Node Pack - Demo Flow","info":"","x":210,"y":80,"wires":[]},{"id":"4444147.9ebe1ec","type":"comment","z":"97d0e573.552e58","name":"Micropi","info":"","x":130,"y":140,"wires":[]},{"id":"a7d7f516.3c84d8","type":"comment","z":"97d0e573.552e58","name":"Audio Rest Api","info":"","x":160,"y":620,"wires":[]},{"id":"8190c3b6.bccc1","type":"microphone","z":"97d0e573.552e58","name":"microphone","endian":"little","bitwidth":"16","encoding":"signed-integer","channels":"1","rate":"22050","silence":10,"debug":false,"active":false,"x":170,"y":520,"wires":[["76f459d.ca67ba8"]]},{"id":"76f459d.ca67ba8","type":"wav-filewriter","z":"97d0e573.552e58","name":"","path":"","mode":"700","x":390,"y":520,"wires":[["ff81bc0.5e39948"]]},{"id":"f546a31e.f5eca","type":"comment","z":"97d0e573.552e58","name":"Microphone and Wav-Filewriter","info":"","x":210,"y":480,"wires":[]},{"id":"ff81bc0.5e39948","type":"debug","z":"97d0e573.552e58","name":"Wav File as a Buffer","active":true,"console":"false","complete":"true","x":640,"y":520,"wires":[]}]
Created 8 years, 1 month ago
Updated 7 years, 4 months ago
  • comment (x4)
  • debug (x4)
  • file in (x1)
  • function (x2)
  • http in (x3)
  • http response (x1)
  • inject (x2)
  • MicroPi
  • Microphone
  • Audio
  • Wav
  • Filewriter
  • Alsa
  • L16
  • stream
  • record
