uc3_webapp
Web app for use case 3: real control lamp
[{"id":"e51dfbdd.5631a8","type":"mqtt in","z":"b255b79c.634ea8","name":"mqttin","topic":"I3523215361","qos":"0","broker":"f1f7b732.115e58","x":94,"y":404,"wires":[["3acdd554.59c7fa","a3a0b5c8.d1bf78"]]},{"id":"8d17eb33.25fc38","type":"mqtt out","z":"b255b79c.634ea8","name":"mqttout","topic":"O3523215361","qos":"0","retain":"false","broker":"f1f7b732.115e58","x":867,"y":318,"wires":[]},{"id":"3acdd554.59c7fa","type":"debug","z":"b255b79c.634ea8","name":"mqttin trace","active":true,"console":"false","complete":"payload","x":279,"y":321,"wires":[]},{"id":"a3a0b5c8.d1bf78","type":"switch","z":"b255b79c.634ea8","name":"message","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Dark","vt":"str"},{"t":"eq","v":"Light","vt":"str"}],"checkall":"false","outputs":2,"x":267,"y":406,"wires":[["3c689436.ea646c"],["a42a1cf7.8e03d"]]},{"id":"444c75fc.54c4ac","type":"ui_switch","z":"b255b79c.634ea8","name":"","label":"off/on","group":"d8e00c2d.d71ea","order":1,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"green","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":659,"y":318,"wires":[["8d17eb33.25fc38"]]},{"id":"796e7500.7e3d1c","type":"ui_gauge","z":"b255b79c.634ea8","name":"state","group":"d8e00c2d.d71ea","order":2,"width":"3","height":"3","gtype":"donut","title":"lamp state","label":"","format":"{{value}}","min":0,"max":"1","colors":["#ff0000","#ffffff","#80ff80"],"seg1":"","seg2":"","x":662,"y":385,"wires":[]},{"id":"9413c744.1bb478","type":"ui_chart","z":"b255b79c.634ea8","name":"histogram","group":"d8e00c2d.d71ea","order":3,"width":"0","height":"0","label":"off/on history","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"step","nodata":"push switch","ymin":"0","ymax":"1","removeOlder":"60","removeOlderPoints":"","removeOlderUnit":"60","cutout":"","colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"x":676,"y":445,"wires":[[],[]]},{"id":"a42a1cf7.8e03d","type":"function","z":"b255b79c.634ea8","name":"light","func":"msg.payload=1;\nreturn msg;","outputs":1,"noerr":0,"x":462,"y":446,"wires":[["796e7500.7e3d1c","9413c744.1bb478"]]},{"id":"3c689436.ea646c","type":"function","z":"b255b79c.634ea8","name":"dark","func":"msg.payload=0;\nreturn msg;","outputs":1,"noerr":0,"x":460,"y":383,"wires":[["796e7500.7e3d1c","9413c744.1bb478"]]},{"id":"f1f7b732.115e58","type":"mqtt-broker","z":"","broker":"m20.cloudmqtt.com","port":"14596","clientid":"Smick_webapp","usetls":false,"compatmode":true,"keepalive":"300","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"d8e00c2d.d71ea","type":"ui_group","z":"","name":"Lamp","tab":"70bf4695.9bbf38","order":1,"disp":true,"width":"6"},{"id":"70bf4695.9bbf38","type":"ui_tab","z":"","name":"UC3 Lamp","icon":"dashboard","order":10}]
Created 7 years, 5 months ago
  • function (x2)
  • mqtt in (x1)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • switch (x1)
  • ui_chart (x1)
  • ui_gauge (x1)
  • ui_group (x1)
  • ui_switch (x1)
