Sleep Timer
I'm using this flow to turn of my TV and hifi equipment after some minutes. Simple sleep timer.
first output: sends "off" as payload after given amount of minutes second output: time left in minutes
[{"id":"76faf37d.b2cc6c","type":"function","z":"8df3d247.bbc66","name":"Sleep Timer","func":"\nvar value  = context.get('value') || 60000;\n\nif (msg.topic == \"value\")\n{\n  value = msg.payload * 60000;\n  context.set('value',value);  \n}\n\nelse if (msg.topic == \"start\")\n{\n\nvar timer = setTimeout(function(){msg.payload = \"off\";node.send([msg,{ payload: \"Ende\" }]);var countdownstop  = context.get('countdown');clearInterval(countdownstop)},value);\ncontext.set('timer',timer); \n\nvar count = value/60000;\n//count = count -1 ;\nmsg.payload=count;\nnode.send([null,msg]);\nvar countdown = setInterval(function() {count=count-1;msg.payload=count; node.send([null,msg]) }, 60000);\ncontext.set('countdown',countdown);\n\n}\n\nelse if (msg.topic == \"stop\")\n{\nvar timerstop  = context.get('timer')\nclearTimeout(timerstop);\n\nvar countdownstop  = context.get('countdown')\nclearInterval(countdownstop);\n\n}\n\n\n","outputs":"2","noerr":0,"x":1270,"y":1060,"wires":[["7f025f32.b44ac"],["a2ec4700.673f38"]]},{"id":"9b2e787.97d9388","type":"ui_button","z":"8df3d247.bbc66","name":"","group":"4e53f268.aaddbc","order":3,"width":"3","height":"1","label":"Start","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"start","x":1030,"y":1040,"wires":[["76faf37d.b2cc6c"]]},{"id":"a8bcf5bc.3524f8","type":"ui_numeric","z":"8df3d247.bbc66","name":"","label":"Sleep Timer in Minuten","group":"4e53f268.aaddbc","order":2,"width":"0","height":"0","passthru":true,"topic":"value","format":"{{value}}","min":"1","max":"300","step":1,"x":1070,"y":1120,"wires":[["76faf37d.b2cc6c"]]},{"id":"ccb1395f.76f848","type":"ui_button","z":"8df3d247.bbc66","name":"","group":"4e53f268.aaddbc","order":4,"width":"3","height":"1","label":"Stop","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"stop","x":1030,"y":1080,"wires":[["76faf37d.b2cc6c"]]},{"id":"a2ec4700.673f38","type":"ui_text","z":"8df3d247.bbc66","group":"4e53f268.aaddbc","order":5,"width":0,"height":0,"name":"","label":"Restzeit","format":"{{msg.payload}} Minuten","layout":"row-spread","x":1440,"y":1080,"wires":[]},{"id":"7f025f32.b44ac","type":"debug","z":"8df3d247.bbc66","name":"","active":true,"console":"false","complete":"false","x":1450,"y":1020,"wires":[]},{"id":"4e53f268.aaddbc","type":"ui_group","z":"","name":"Steckdosen","tab":"95d17d8a.8e1d8","disp":true,"width":"6"},{"id":"95d17d8a.8e1d8","type":"ui_tab","z":"","name":"Schlafzimmer","icon":"fa-bed"}]
Created 10 years, 6 months ago
  • ui_button (x2)
  • ui_group (x1)
  • ui_numeric (x1)
  • ui_text (x1)
  • timer
  • sleeptimer
  • sleep
